AC/Heat making noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tanner2017, Oct 16, 2019.
  1. Tanner2017
    Tanner2017 Junior Member
    ames iowa
    Hello, my air conditioner and heat is making a noise chipping like noise. It doesn't matter the temp not the speed im going. It does speed up when you turn the air speed up. It also doesn't affect temperature thinking fan? Thank you in advance.
    52,858
    baseball card in the hvac fan. it is below the cabin air filter, behind the glove box
    fotomoto likes this.
  3. Sharnold
    Sharnold Active Member
    409
    126
    Alabama
    Had one do this because the cabin air filter had been pulled into the fan
    Tanner2017 likes this.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Debris in the fan box. Remove and replace cabin air filter behind glove box (plenty of how-to vids on the youtubes) and clean the fan assembly as thoroughly as you can. While you're at it, apply some air system cleaner/freshener product too.
    GOOD LUCK!
  5. Tanner2017
    ames iowa
    Sorry for taking so long to reply. Thank you, I will bet this is it. Will update once I try it!
