AC/Heater Blower Issue
Discussion in 'Gen 3 Prius Main Forum' started by Auszero, Dec 15, 2021.
  1. Auszero
    Auszero New Member
    Tucson, AZ
    I have a 2015 Prius with an intermittent AC/Heater blower issue. When I turn the AC on it blows however the blower eventually stops. I power the climate system down and start up again and it blows for a while. The more powerful the fan is blowing the sooner the blower craps out. If I turn the heater on the blower does nothing at all regardless of fan speed.
    So far I've replaced the blower with I believe the integrated controller (the unit is a "A-Premium Heater Blower Motor with Fan Cage Replacement" from Amazon) and I still have the same problem.
    What do I replace or look at next?
  2. BZzap!
    BZzap! Senior Member
    1,607
    877
    Watch this video from South Main Auto. It is a Nissan that he is repairing but contains the same exact principles the Prius uses. The blower motor speed is controlled by a pulse width signal.
  3. Auszero
    Auszero New Member
    Tucson, AZ
    Thanks, the third gen Prius has the resistor built into the blower motor so it should have been replaced when I replaced the motor assembly. Any idea of what should be next? I can't imagine it would have the same problem twice.
    49,492
    idk, but it sounds like something is overheating or tripping and has to cool down or reset. a relay maybe?
