1. Patrick Wong
    18,210
    6,517
    Which raises the question, what was it clogged with? I assume bits of the compressor and oil?
    You can declare an unqualified success, then.
    What did the old oil look like, and did any metallic bits or other debris come out with the oil?
    Thanks!!
  2. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    EXCELLENT! Far too many "AC Techs" do not know to DRAIN the oil prior to refilling (y)
    Paul Schenck likes this.
  3. Aaron Nutter
    Aaron Nutter New Member
    2012 Aqua
    Thanks for sharing that video Popp. It has helped me a lot.
  4. Soniaprius
    Soniaprius Junior Member
    Usa
  5. ashton.agar
    ashton.agar New Member
    New york
    2011 Aqua
    have a 2010 Prius. when the engine starts the air conditioner shuts off and blows hot air.
    problem is that When the engine stops the a/c starts and blows cold air. The hybrid battery is fully charged and getting 50.2 mpg
    don't know why it's happening? ??
  6. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    2010 is gen 3 Prius so you should post this to a correct forum. But if I had to guess maybe it’s the temperature control flap not going fully to cold. And when engine is running coolant is going through the heater core and counteracting the cooling effect of AC.
  7. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    My 2005 has been telling me the coolant valve isn’t working properly. The result is heater works sometimes and doesn’t at times. I get a code though P1122.
    iPhone ?
  8. JC91006
    16,934
    8,643
    You mean code p1121? Maybe your coolant is low too
  9. Paul Schenck
    524
    307
    Fresno, California
    It looks like this just in front of the inverter.
    iPhone ?
  10. PriFi
    PriFi Junior Member
    22
    HI
    Paul, did the faulty valve affect your AC?
    My center vents / registers don't blow any air, hot or cold. I have the P1121 code too.
  11. Paul Schenck
    524
    307
    Fresno, California
    That’s a good question, California has has
    Rather mild weather, and I did notice the auto a/c had trouble keeping me happy at 72 sometimes I had to adjust to 69 in sunlight or 74 when it was 46 outside. I suppose the valve would have made the water flowing through the heater core cooler during the times when it was 80 outside and warmer when it was 46 if it could have made the adjustment.
    iPhone ?
  12. Richard Figueroa
    Richard Figueroa Junior Member
    Hello people...
    I have a 2007 prius and the A/C is throwing hot air all time. It doesn't give a code, so, I add gas and start cooling, but, jus for one day.
    Can I use refrigerant R-134a with leak sealer?
    Lisa Tyrrelk likes this.
  13. Fern1461
    Fern1461 Junior Member
    Houston, Texas
    Only use R-134a WITHOUT oil/additives. This is an electric, hybrid ac compressor and the innards are delicate and prone to failure with wrong stuff. If you need peg oil, you need to get the special version for the Prius. Hope this helps.
  14. Richard Figueroa
    I thing I have a lick. I put the R-135a in the morning and, before noon it was complitly empty....
  15. Sailesh
    Sailesh New Member
    Fiji Islands
    Hello
    My 2004 Prius does not cool when at idle/stop but cools when in motion. What could be the problem?
    Appreciate your assistance.
  16. Patrick Wong
    18,210
    6,517
    Maybe the radiator fans are not working?
  17. Oyeleye Amos
    Oyeleye Amos New Member
    Nigeria
    My A/C compressor is not taking gas during refill. Please help.
  18. Paul Schenck
    524
    307
    Fresno, California
  19. Mr President
    Mr President Junior Member
    Lagos Nigeria
    Hello prius owners, good day to you. My brother and I own a prius, 2005 and 2007 respectively. Both having different AC issues. Starting with the latter, my AC cools only when the temperature is low, early hours of the morning or later in the evening. Please what could be the problem. Temp is set to LO, It didn't have this problem before. I need help asap.
  20. Mr President
    Lagos Nigeria
    My brother prius refuses to cool, only blows hot air, he has replaced the compressor, evaporator and condenser. It cooled for 2 days and went back to the same problem. We noticed the fan it's rotating but we were advised that it's because the Compressor isn't engaging. We both help, any thoughts please?
