AC line disconnect instructions 2017 Prius 4
Discussion in 'Gen 4 Prius Technical Discussion' started by Jwy, May 9, 2018.
  1. Jwy
    Jwy Junior Member
    i am asking for directions on how to disconnect the high pressure line on my damaged 2017 Prius.any help would be appreciated.
  2. Elektroingenieur
    2,515
    3,288
    Three Touring
    Find this information, including safety precautions for work on high-voltage components like the air conditioning compressor, in the Repair Manual, available by subscription to techinfo.toyota.com, toyota-tech.eu, or toyotamanuals.com.au. If you are in the U.S. or Canada, your local public library may also sponsor access to the ChiltonLibrary service, which has the text and illustrations from the Repair Manual for the 2016 Prius, most of which also applies to 2017 models.
    As the manual mentions, some of the piping clamps on the refrigerant lines are destroyed during removal and, like the O-rings, cannot be reused.
  3. Mendel Leisk
    42,238
    @Jwy: your location might be relevant, are you in the States?
    RCO likes this.
