AC making this noise and not blowing cold after belt replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cwal, May 24, 2019.
  1. Cwal
    Cwal New Member
    Savannah, GA
    Thank you very much for your time and advice.
    I would call the dealers service dept and tell them what’s going on. Don’t start the car, don’t drive the car. If that belt is not turning the entire time the engine is running you can overheat the engine.[/QUOTE]
  2. ChapmanF
    18,146
    Are you actually watching the drive belt go around the idler pulley and saying it stops a moment later? While the engine continues to run?
    I'm finding that hard to picture.
    strawbrad likes this.
  3. Mendel Leisk
    41,400
    SFO likes this.
  4. Leadfoot J. McCoalroller
    8,075
    7,557
    Pennsylvania
    2018 Prius c
    I think there are some pretty big misunderstandings and miscommunications going on here.
    In a 2nd generation Prius the drive belt has no effect on the air conditioner unless the engine starts to overheat, at which point the computer will shut down the A/C in an attempt to stop the overheat condition. And then, the belt is only implicated if it is what caused the overheat.
    #24 Leadfoot J. McCoalroller, May 24, 2019
    Data Daedalus, strawbrad, SFO and 2 others like this.
