  1. KARL QUIN
    KARL QUIN New Member
    East Sussex
    Hello all, my AC doesn't seem very cold.
    I have put the AC on and can see the gas flowing but warm air is coming out of the vent?
    Any advice would be most welcome .
    Regards Karl
    49,700
    welcome!
    perhaps it needs recharging?
  3. Patrick Wong
    18,200
    6,479
    If you can see the refrigerant flowing in the sight glass, it is likely that the system needs a bit more R-134a to be added. There is very little difference in refrigerant level, between the system blowing ice cold and inadequate performance as you are currently experiencing.
  4. KARL QUIN
    East Sussex
    Thanks for your replies.
    Yes maybe its a little low.
    TMD want £89
  5. KARL QUIN
    East Sussex
    Can I buy a can of R-134a still?
  6. Patrick Wong
    18,200
    6,479
    You can; make sure it doesn’t contain any oil or leak sealer. Get a hose with a pressure gauge and do not overfill. Depending upon ambient air temp, you may need the low side pressure to only be around 30 psi.
  7. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    You can in the U.S. Not sure how easy it is to buy in England though.
  8. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    Rule out leaks first!
    Otherwise you will be in the same position again, and maybe soon, depending on the severity of the leak, if there is a leak.
