AC Problems — Strange Noises, Hot Air, etc.
Discussion in 'Gen 3 Prius Technical Discussion' started by wesleyNLC, Nov 24, 2018.
  1. wesleyNLC
    wesleyNLC New Member
    Arkansas
    Hey all. Thanks in advance for your wisdom.
    Within the last 2 weeks, the AC in our car made a horrible noise. I turned the AC off with the car on, turned the AC back on, and it didn’t work at all. The controls would prompt the screen like normal, but nothing would happen. I turned the CAR off, back on, then the AC worked.
    Today, cold air will not blow out of the main or floor vents, but it will blow cool air out of the defrost vents.
    Does anyone have any ideas on what I can check/fix myself and not spend a ton of money getting it fixed?
  2. PriusCamper
    PriusCamper Senior Member
    13,449
    5,430
    Pacific Northwest, USA
    Pretty sure this works for Gen3, but in Gen2 with the car on If you turn on and off headlights three times while holding down the info button (or maybe it's the display button) you'll get a diagnostic screen for dashboard equipment and you should be able to go thru the menu and get some error codes and enter them into a google search. Or alternatively, because it's specifc to AC, find a high rated&honest Auto AC repair business in you area to do a diagnosis & estimate.
    Grit likes this.
  3. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Your AC compressor is already toast! Get another one, and replaced with.
  4. ChapmanF
    19,008
    PriusCamper gave instructions for getting audio/nav diagnostics, but HVAC diagnostics are different. Just hold down the AUTO and RECIRC buttons together while turning the car ON. Any two-digit trouble codes will cycle through the left side of the HVAC display (where normally is shown the set temperature).
    Techstream will also read HVAC codes (they generally start with B14).
    -Chap
    PriusCamper, jerrymildred and Grit like this.
