AC stops working at slow speeds in traffic
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by PriusCamper, May 31, 2026.
  1. PriusCamper
    PriusCamper Senior Member
    13,467
    5,435
    Pacific Northwest, USA
    In the 2013 Prius C owner's own words:
    "Today while in very slow traffic we had the same problem as I'd been concerned about last summer: the car overheat warning light comes on when running the AC while driving slowly (about 6-12 mph). The AC worked when we were going over 8 mph but not so much while traffic was stopped. Interested to hear what you think might be going on."
    I did 100K mile work on this Prius C last week with new spark plugs, clean out of the intake system, oil change, etc.. And driving the car home 15 minutes and back the AC worked fine. Engine coolant reservoir was low, but not much and just a tiny bit low under radiator cap.
    The problem evidently existed before front end damage led to a bodyshop replacing the condenser. Also the useless idiots at Toyota Stealership looked at it in Winter and said system had leaks and needed everything replaced, which makes no sense because AC works fine other than when things heat up and car drives slowly.
    Back in the day there were Auto AC specialists, but these days it seems only regular auto shops are the only option, but the most trusted shop in town charged a friend who owns a Honda Hybrid $125 an hour to give her the same BS routine of detecting minor leaks after charging the system and more than a year later her AC is still going strong. Seems like detecting minor leaks is the standard operating procedure for charging people a fortune these days.
    Anyone got any advice?
    Any sense of what's wrong?
    #1 PriusCamper, May 31, 2026
  2. PriusCamper
    13,467
    5,435
  3. ChapmanF
    19,033
    There are electric fans under the hood (fans? I don't know how many are in a Prius c, but the bigger Prii all have two of 'em, as far as I know) to make sure enough air keeps flowing through the condenser and radiator when you are stopped or moving slowly.
    Are you positive the fan(s) work?
    PrimeDan and Tombukt2 like this.
  4. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    So you're saying that going below the 6 mi an hour the airs getting warm etc . Are the radiator fans running just out of curiosity? this is replaced condenser? You know there have been some issues with some condensers . Like these sort of things . Something about internal. Of the core how it's made .
  5. Tombukt2
    13,864
    2,519
    Durham NC
    What do the gauges say if you hook up gauges to the system both gauges high and low what do you see thru the cycles any high readings that collapse etc . To me it sounds like you've got a metal line that's very crimped you got a serious flow issue . Seems like . We have a cold fat silver line and a warm skinnier line ?
  6. PriusCamper
    13,467
    5,435
    We haven't got to the gauges yet... But now that I think of it the horn wouldn't work and I fixed it last week by checking the fuse and connectors and got it working just by cleaning and inspecting so I'll do the same for the fan. I wonder which fuse is coolant fan? The diagrams you can find online for "Prius C" fuseboxes never seem to show the correct one...
    Prius C is such an odd car and no longer in production. It's amazing how many things were designed differently for such a short production run. I always thous the Yaris looked nicer than the C, but no Yaris hybrid in the US.
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,117
    6,975
    Texas Hill Country
    The poor customer is telling you what the problem is; the engine is overheating. Solve that first and the ac will be ok; ok but not great since it has a slow leak.
    First, if the engine or inverter cooling system is overheating, the ac will be disabled.
    Second, if the engine or inverter does not overheat while moving faster than 12 mph, it sounds like the engine has to continue running and the radiator fan(s) are bad. If the engine does not stop at low speeds it also has a weak hv battery. Probably some off brand aftermarket hv battery.
    Finally, the ac system has a txv refrigerant metering system which will compensate for some degree of low refrigerant. Until its almost gone or there is a very high cabin heat load.
    BiomedO1 likes this.
  8. ChapmanF
    19,033
    I find the c a very cute car, plus they put better colors on it than the liftbacks got. I still make an aww face every time I see one. If I didn't occasionally carry bigger stuff, I'd probably be driving one.
    I spotted one last night with quite nice-looking wheels, but I didn't take a picture on my way into the place, and it was gone by the time I came out.
  9. PriusCamper
    13,467
    5,435
    Working on them is so much different too... I remember the first time I deep cleaned one. It was a lesson in how Prius engineers went about eliminating as many parts as possible and making the parts they did use as small as possible. If you lived in a big city this car is ideal.
    I also installed a Nexpower Energy Sodium-Ion pack in a different Prius C last week and pack sits with 12v under, not behind, back seat and to access the pack you have to remove a tubular frame that holds up the back seat.
    Also the battery pack is more like a bolt together wrapper of sheet metal work rather than proper covers on a chassis. It's an entirely different design too where some electric components are actually bolted to white plastic caps that hold the modules on a rack.
    Also, the sheet metal edges for Prius C packs never had any finishing after they were pressed so they're razor sharp. Still got a band-aid on my index finger that isn't healed enough yet even though that pack sliced it last Tuesday. Just another day or two and I can get back to using my favorite index finger again for everything.
    Best part about Prius C is doing the spark plugs and cleaning the intake manifolds you don't have to remove the windshield wipers and its cowling like in Gen3, or unbolting the relay box like in Gen2. You also don't have to remove the airbox to access the throttle body! It's just full access and easy to do with basic tools. Made the job go much quicker.
  10. Leadfoot J. McCoalroller
    8,290
    7,806
    Pennsylvania
    2018 Prius c
    There's only one cooling fan in the c model, and these symptoms are about right for the fan running poorly or not at all.
    We love ours as much as the day we bought it. Odometer will hit 100k next week or the one after.
    PriusCamper likes this.
  11. PriusCamper
    13,467
    5,435
    And thanks to your advice I decided to not clean the EGR as part of the 100K mile maintenance. My impression from the spark plugs is these smaller engine burn less fuel and burn it more clean than a standard Gen3. And maybe someday I'll need to clean one, which in a Prius C is right on top with easy access.
  12. Tombukt2
    13,864
    2,519
    Durham NC
    It's a Gen 2 with an EGR cooler isn't it more or less ?
  13. ChapmanF
    19,033
    And an electric water pump and I guess half as many front fans.
  14. Leadfoot J. McCoalroller
    8,290
    7,806
    Pennsylvania
    2018 Prius c
    It might be more accurate to say it's the gen 2 engine block dressed with gen 3 technology, accessories and equipment.
    They held the distinction of being the most automatically-produced car in the world. Not sure if they have retained that record. But the commercial point of the Aqua/Prius c was to fine-tune the design and then keep pumping them out day and night with relatively few changes along the way.
    Not that many showed up in the USA, but Toyota made mountains of them for the rest of the world.
  15. Tombukt2
    13,864
    2,519
    Durham NC
    Most of the C I see are going souf at about the 250 K . Quite respectable for that design . Gen2 has my stereo n all in already . And I've ice cold air.less than 2K in any of them . cannot get out of those.
  16. rjparker
    11,117
    6,975
    Texas Hill Country
    The one person I have known with a c loved it as a commuter car with a mini v hatchback style and good mpg. It was noisy and not great on high speed freeways.
  17. Leadfoot J. McCoalroller
    8,290
    7,806
    Pennsylvania
    2018 Prius c
    Yep, they sure are buzzy on a hill pull. And that short wheelbase does not help for high speed stability. But there are always trade-offs to be made.
    For our use in suburban Pennsylvania, an area with lots of 45mph roads and relatively few interstates? It has been a brilliant family car for us. Our daughter particularly likes trips in it.
    I fit my 6'4" self in there better than the big Prius, mostly because there's no center console penning me in.
    I'd love to be able to replace it with another one once we're done.
  18. Tombukt2
    13,864
    2,519
    Durham NC
    By the time you're out of that byd will be sending some realness our way
  19. rjparker
    11,117
    6,975
    Texas Hill Country
    I think the Corolla hybrid has taken its place as a value hybrid with excellent mpg combined with modern safety systems.
  20. Leadfoot J. McCoalroller
    8,290
    7,806
    Pennsylvania
    2018 Prius c
    If only they were selling the hybrid hatchback model in the USA.
