AC was great in the summer but...
Discussion in 'Gen 4 Prius Main Forum' started by MichelleStone, Jan 5, 2017.
  1. MichelleStone
    MichelleStone Senior Member
    549
    819
    Mariposa, CA
    the heating system is somewhat lacking. I'm really glad I got the heated seats. FWIW, I live in the foothills of Yosemite and my driving temps haven't been below 45 degrees.
    One thing that I don't like is that when I set the heating to push air out the dash vents, the wind screen fogs up. I haven't been able to heat the cabin to the point where this doesn't happen to date. My trips are generally around 20 minutes or so and I'm usually driving in ECO mode.
    I've got a 200 mile trip planned for tomorrow and we'll have some wet cold weather. I'll get in some testing on this issue.
    'LectroFuel likes this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    FWIW, I think you'll have to come out of ECO Mode for the heater to work best. Like you, though the heated seats are just as good, if not better.:)
    greenmonster01 likes this.
  3. MichelleStone
    549
    819
    Mariposa, CA
    I'm really surprised how well the heated seats work. I thought plastic seats and heated? I didn't think it was a winning combination but they are extremely effective.
  4. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    I'm staying in Yosemite West right now for 4 days! I'm hoping I can get out of the driveway tomorrow with the tire chains because of the snow. I heard this is the biggest storm in the past 5 years. It's supposed to be 19ºF tonight and there's a bunch of rain in the forecast.
    Have you tried the defroster front windshield and rear? It works for me to de-fog the windshield
  5. bisco
    52,901
    30 degrees here today, no heat on. this is what separates the men from the boys. or girls.:p
    MrMischief likes this.
  6. MichelleStone
    549
    819
    Mariposa, CA
    I know that Yosemite is closed for the weekend. They are expecting flooding from the Merced River. You go through the valley to get out or go down through Oakhurst? I hope you've got food for a few days. Rain and snow coming late Friday night.
    I have tried the rear window defogger and it does indeed work. My wind screen up front only stays clear if I have my dash vents turned off. That makes for a cold cabin. I'll experiment with my settings tomorrow.
  7. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
    Is your system in Auto?
    You aren't using recirculate mode, are you?
  8. bisco
    52,901
    do you press the front anti fog button for the windshield?
  9. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    Sounds like you have recirculate on. Whenever it's cold out I see someone with warm weather state plates trying to see out fogged up windows. I always assume that it's because they have recirculate on, I don't know why they can't figure it out. I've been in much colder weather with the Prius and I have no problem with fogging or with the heater working effectively in eco mode. It takes awhile for it to warm up but leaving it in auto set at 70 everything works just fine. It was 3ºF this morning, no issues.
    Put the heater on the floor setting where it belongs, make sure recirculate is turned off. My guess is that will resolve your fogging issue. The lack of heat issue is probably because the car isn't getting warmed up enough to provide enough heat.
  10. yeldogt
    yeldogt Active Member
    810
    313
    NE
    Make sure it's in Auto. With our 2011 I found the ACC to be ineffective with ECO in extreme weather (hot or cold). We saw no real difference in MPG using it ... so we stopped placing it in ECO. The 2016 seems to take a bit longer to heat up vs the 2011.
    You do understand the 2016 have a new system that try turns off heat/cool to unoccupied areas of the car. IMO it is taking things too far .. especially if you have to use the electric seat heaters. Was very uncomfortable the first few times I drove the car -- the system works great in Auto with the position system off.
    Both of our Prius have the heated seat option. The heat is more uniform in the 16's. To bad Toyota did not use the same seats as our Lexus CT -- more comfortable and the seat heater has a variable adjustment.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    To get the best heating, make sure drive mode is "Normal" and heater is not set to "S-Flow" and not set on "Eco" .
    What I do on cold days is firstly switch on the heater (auto) and rear defogger, select front defogger on heater, then after a while when the windscreen is clear, select "Auto Fast mode" (press Auto button to cycle through the modes, Fast, Eco and Normal) and make sure S-Mode is off and Dual climate is off so the car gets evenly heated. I also use the drivers heated seat, set on high.
    A higher temperature set on the heater doesn't make car warm up quicker, but it takes longer to reach higher settings.
    This is of course the most inefficient in terms of mpg, but IMO the most efficient and quickest way to heat the car up.
    RCO likes this.
  12. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    AND that it is NOT in recirc.
    AND not in ECO mode.
    AND that the temp is set at least to 75 F (higher is better)
    AND do NOT manually turn the A/C OFF when that light comes on.
    It is the A/C running intermittently that accomplishes the dehumidification.
    If you need more defrost power, turn the front defroster ON.
    Alas, small cars don't heat good.
    alanclarkeau and kithmo like this.
  13. bisco
    52,901
    mine is like the sahara.
    krmcg likes this.
  14. Prodigyplace
    12,720
    11,852
    Central Virginia
    You turned off the AC light, didn't you? The car uses the AC to dry the air before it is heated to avoid fogging the windows.
    Either that. or quit hyperventilating :D
    alanclarkeau likes this.
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Barren and sandy??? :ROFLMAO:
  16. bisco
    52,901
    that's one way to describe it.:whistle:
    RCO likes this.
  17. Prodigyplace
    12,720
    11,852
    Central Virginia
    I thought you were not at the beach yet...
  18. bisco
    52,901
    34 days, but who's counting.:p
  19. Prodigyplace
    12,720
    11,852
    Central Virginia
    Driving the PiP or a new Prime? :D
  20. bisco
    52,901
    nah, hycam, much more comfortable, and still 42 mpg.
    Prodigyplace likes this.
