AC won't blow cool air only hot; AC selection on screen erratic
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by MslCmdr, Feb 5, 2024.
  1. MslCmdr
    MslCmdr New Member
    2018 Prius Prime
    What can I do to fix my 2018 Prius Prime Advanced? AC won't blow cool air and only blows hot air; AC selection on screen isn't immediately selectable on start up; and when it becomes selectable, it is erratic. Blown fuse? Software problem? Ideas please. Thank you!
  2. BiomedO1
    BiomedO1 Senior Member
    1,446
    790
    SacTown, Ca
    low refrigerant. When the car heats up, the gases expands and pressurizes the system. this releases the low pressure cut-off solenoids; that's why your system will operate after warm-up. Take it to an AC shop to get it diagnosed.
