Acceleration Issues - HELP!
Discussion in 'Gen 2 Prius Main Forum' started by Patrick Faulds, Oct 25, 2017.
  1. Patrick Faulds
    Patrick Faulds New Member
    Atlanta, GA
    Starting in the last 3 days I've had some strange issues with my 2007 Base model Prius (195,000 MILES) and hoping someone can shed some light on it.
    Three mornings ago while driving to work (about a 45 minute drive) The red triangle warning light came on, along with the little car with exclamation mark light on the center display screen. Nothing about the way the car was driving changed and I made it the rest of the way to work without concern. On the way home the light was still on, but the car still appeared to be handling fine. I decided to stop at a parts store on the way home to have them check for codes anyway. As the guy came out with the code reader he asked me to crank the car back up, which I did and whaddya know... no light. He tried to read the codes anyway and the only thing he found was P1121: Coolant Flow Control Valve Position Sensor Stuck. When I got home I looked up some information on that code and figured I'd fix it myself.
    Next day (yesterday) I go to drive to work again and notice the car isn't pulling away normally, but no warning light came on. It would go, but felt sluggish. It did it pretty much all the way to work at ever red light, but it was fairly subtle. Coming home everything seemed normal for the first half of the journey, then while doing 50mph on the freeway the same two lights (red triangle and car with !) come on and the engine starts revving hard, but the car doesn't pick up speed. I literally took my foot all the way off the peddle and it kept revving while not losing speed, like it was stuck at around 50ish mph. If I put my foot on the peddle it would pick up speed but VERY slowly - like, foot to the floor would make it pick up 1 MPH for every 20 yards maybe. I was doing my best to get to the shoulder and all of a sudden I realize that the car is slowing, despite my foot being all the way down on the peddle. I manage to get to the shoulder and come to a stop. Not sure why, but I decided to turn it off and back on... and boom, everything is fine, except for the lights still being on. I drive another few miles with no issue and get off at the next exit to take it back to somewhere with a scan tool. As soon as I get off the interstate it starts again. Not responding to my foot pressing the gas peddle, revving hard etc. Every single red light I get to I turn the car off and back on again and it works fine for a few minutes, like turning it off reset the problem. Finally get to the parts store and the guy tries to scan for codes - this time with both lights still on - and nothing. Still just the P1121 code about the coolant valve. Was able to drive home without any issues what so ever.
    Took it out again last night with a mechanic friend (doesn't work on Toyota's and knowledge of Hybrids is limited just to see if he could figure it out). Everything was fine for about half an hour but just before we got home we lost it again. Around 35ish mph the car just stopped responding to anything I was doing with the accelerator pedal and began losing speed. Pulled over to the side of the road, cut it off and back on, and drove fine back to the house.
    Mechanics friend's best guess is maybe the Throttle Position Sensor is going out. Was hoping someone on here could let me know if that sounds right or if it might be something else.
    (I should say the hybrid battery was replaced about 5 months ago and I haven't had any other issues until now)
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Replaced with what?
    Raytheeagle likes this.
  3. Patrick Faulds
    Atlanta, GA
    The battery I got was a reman 2nd Gen, 6.5 Ah 7.2 Volts from greentecauto. It has an 18 month warranty.
    (I tried to post a link to the website so you could see for yourself but it wont let me)
  4. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    First thing I would address is the coolant control valve code. It may be that the control valve is bad, then when the car begins to overheat due to the bad valve, the ECU dramatically limits output power. Fix this and then if you still have problems, address them from there.
    P1121 - Coolant Control Valve Replacement (with pics) | PriusChat
  5. Patrick Faulds
    Atlanta, GA
    I did notice that whenever the warning lights come on the little air vent in the passenger side back seat starts blowing (or sucking?) air. Is this a normal response to the warning lights or could it be a symptom of overheating?
  6. Kevin_Denver
    581
    425
    Denver, CO
    I can't say as I have never had this issue on my Prius. I will say as someone who works with software, that's its possible that when the coolant control valve code triggers, the car goes straight into a "protected" mode, which could trigger many different changes in the car, including running the HV battery fan at maximum. There are probably only a few different "protected" modes in the software. It's easier to build a single or just a few "protected" modes when any fault occurs in the software, than it is to spend the time to build modes which address each and every sensor failure. This is why I would say address the coolant control valve first, before trying to address other problems in the car.
  7. bisco
    52,904
    usually means a bad hybrid battery. but you need to have the codes read with toyota tech stream to make sure.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    What's to figure out? Code reader identified the problem. Chances are, it's just the coolant control valve. But it's a good idea, as @bisco said, to check all the codes with a reader that can see all the hybrid codes before investing in any parts. If P1121 is, indeed, the only code, replace the valve.
    But at any rate, don't go destroying the hybrid system by driving with a bad inverter coolant valve.
    pilotgrrl and Kevin_Denver like this.
  9. bisco
    52,904
    would the control valve cause the battery cooling fan to come on high?
  10. jerrymildred
    11,517
    14,171
    Tampa, FL
    I'm not sure. It may be that the system detects high temperature in the inverter and assumes the possibility that the battery could also be hot but the sensors not reading it. Sort of a fail safe since, if there was no problem with inverter cooling, it might be wise to assume heat from current would be similar at the battery and the inverter. Just a theory.
  11. Patrick Faulds
    Atlanta, GA
    My only hesitation in putting it all down to the control valve and an overheating issue is the sluggish acceleration after the car has been sitting, even overnight. I can only assume it’s all related as it all started happening around the same time, but I wouldn’t have thought an overheating issue would have presented itself so immediately in a vehicle that’s been sitting idle for hours. Either way, I’m taking it to a local Toyota specialist on Friday morning (won’t drive it until then) to have him check for any other codes and we’ll take it from there. Fingers crossed for a simple fix!
  12. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Check to make sure your coolant isn't low. Sometimes that will throw a p1121.
    This would cause the car to overheat.
    But it certainly sounds like a hybrid battery issue. Make sure the scantool being used can read Hybrid specific codes.
    You should check the voltage of each of the 14 battery blocks as well as Hybrid Battery Delta SOC. (state of charge).
    My guess is your Delta SOC is above 20 and a module has failed, code P30xx. Maybe even a P0A80.
    You are definitely putting yourself and the car at risk by driving it like this. You have a failure that need to be addressed.
    pilotgrrl, jerrymildred and valde3 like this.
  13. dolj
    dolj Senior Member
    8,657
    4,406
    Wellington, New Zealand
    You better dig out your paper work and get ready to make a warranty claim.
    It could be a normal response, if the codes causing the lights were HV battery related and yes, it could be overheating. But HV battery not engine overheating.
    Nice theory, but there is no such "protected" mode.
    No.
    My bet is also that when you have the codes read with a capable reader, there will be HV battery codes.
    The P1121 does mean you will need to replace the coolant control valve, the other codes will show you what else is wrong.
