acceleration over uneven road surface while braking
Discussion in 'Gen 3 Prius Main Forum' started by Laird Banks, Aug 24, 2010.
  1. Laird Banks
    Laird Banks Junior Member
    23
    NYC
    Could the NYS New Car Lemon Law Program approve my 2010 Pruis into the program. This is an unsafe, dangerous engineering design flaw which effect all.
  2. Joe166
    Joe166 New Member
    720
    96
    South Florida
    And you just discovered this?
    Just out of curiosity, what color is the sky in that world you live in?
  3. teeasal
    teeasal New Member
    420
    50
    ON, Canada
    No they won't because it's not cause by slingshot mechanism and it's not accelaration. It was a pause in the braking action only making you feel like it was acceleration. the car was still slowing down but at a sudden slower rate of deceleration for a split second.
    The split second was reduced by software to almost nil. My Prius was purchased after the fix but I've still experienced similar feeling during a bump on the road while I was braking before a red light. The front wheels were momentarily airborn and it feels like the brakes failed. But as soon as the tires hit the ground again, the brake feeling came right back.
    I don't think this is only affecting the Prius. It was reported that it affects all cars with anti-lock brakes to different degrees. The Prius had this problem more noticable and it was fixed. All cars have design flaws and if the flaws are not serious and got fixed, they don't fall into the category of lemons.
    I think you'll do better to enter into the lemon slingshot competition, than spreading unscientific rumours like this.
  4. bwilson4web
    15,518
    No but it looks like you joined in September 2009 so if you bought your Prius before February, there is a chance you did not get SSC-A0B applied. If you'll take your Prius to the Toyota Service Center, they'll put it on without a charge. BTW, we had one case of a Prius that didn't get the patch so it is perfectly OK to ask the service writer to have a technician check the brake software version. Bring us the identifier and we can check to see that you got the right one.
    GOOD LUCK!
  5. Laird Banks
    23
    NYC
    Thank you for your response, but this has already been done and the problem still exists and realize in their last patch they had attempted to resolve it. It didn't work. Thanks anyway.
  6. Laird Banks
    23
    NYC
    Interesting response, as I neither have introduced you to my 2010 Prius, nor have you driven it. The acceleration occurs in "real time", is not any misunderstanding and your insinuation of an unscientific overview is in fact...incorrect. Please do not respond.
  7. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    WOW sounds like it's time to junk the car.:eek: I'll give you $1000 cash right now for it.:rolleyes:
  8. Laird Banks
    23
    NYC
    Actually not, it's been to several toyota dealers for this complaint in order to conform with requirements for NYS-DOS. I'm not trying to be a smarty-pants, this is a truly serious problem. I've been dealing with it since the car was purchased. Didn't just wake up to a blue sky and smell the coffee. Thanks for your response.
  9. telmo744
    telmo744 HSD fanatic
    2,178
    768
    Portugal
    This is a forum, it's usual to get answers to a post. :)
    And having the brake fixed, if you feel is not ok, just get it to the dealer again to get it done properly.
    Edit: seen you have done it before. In that were the case for me, I would go back until problem fixed, because on thousands of other cars the issue has been resolved. If there is another annoying fault they should also find it and solve.
  10. Laird Banks
    23
    NYC
    I wouldn't be so proud of having anything to do with these vehicles. Please don't respond and get a haircut.
  11. ozarkgolfer
    ozarkgolfer Junior Member
    76
    Rogers, AR
    Are you able to replicate the problem on demand and if so could you post a video of the issue?
    I assume you have taken your Prius to move than one dealer for resolution? What has been their explanation and/or attempted resolution?
    Unfortunately, you are going to be met with sceptism on this board as it has seen it's fair share of owners either disapointed with their purchase, unable to make the payments and trying to find an 'out' or just plain trolls.
  12. Laird Banks
    23
    NYC
    Four (4) times, 2 different Toyota dealers. I agree. Refer to the above stated "Title".
  13. teeasal
    teeasal New Member
    420
    50
    ON, Canada
    Sorry, I'm not responding to you but just clarifying my comment of "unscientific rumours" to the rest of the Forum members. So please do not read my response, Mr. Banks.
    By "unscientific rumours" I mean it's NOT a "slingshot" mechanism, and it's NOT "acceleration".
    This forum is fun:D
  14. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Mr Banks, This is a tough group and sometimes not very helpful. Slinghot acceleration has also been documented in other cars.
  15. Laird Banks
    23
    NYC
    Prior auto's: 03, 07 Infiniti FX45. The prius is not comparable in any way....good or bad. Purchased Prius outright. No payments. No $ difficulty. Seeking resolution thru NYS-DOS.
  16. bwilson4web
    15,518
    Are you able to reproduce this at will?
    The reason I ask is I have an accelerometer that can document the effect:
    Send me a PM with your address and we can document what is going on.
    Does it happen at any fixed spot? If so, let us know a Google map identifier and we'll use "Street View" to document the road surface.
    What I'm proposing is gathering engineering data and documenting the problem. Having empirical evidence goes a long way when filing a formal complaint.
  17. Laird Banks
    23
    NYC
    ACCELERATION: as in the car moves forward at a faster pace. The term "Slingshot" is the product of the action which takes place when the car LURCHES forward at a faster rate than it was previously moving. Fun and on target. Find another vicitm.
  18. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    Just show a video of your car speeding up with the brakes applied.
    So you brake at say 30 mph, and suddenly you are going what, 35 mph?
  19. Laird Banks
    23
    NYC
    I appreciate your response, but am attempting to resolve and already on a path. Data already documented as suggested.
  20. firepa63
    firepa63 Former Prius Owner
    1,761
    208
