Acceleration problem after spark plug change
Discussion in 'Gen 2 Prius Main Forum' started by Purple Penguin, Jul 4, 2016.
  1. Purple Penguin
    Purple Penguin New Member
    I have a 2007 Prius with ~180000, which runs great. The mechanic shop I used for oil change suggest me to change spark plug because they are dirty. After the change, I found I cannot step on the gas pedal too hard for acceleration. The car will hesitate, choking or die if I try to accelerate too fast. But if I step on the gas pedal gently, and let it reach the desired speed in a slower way, it has no issue. I went back to the shop and they replaced with another set of 4 plugs, and no improvement. I checked air intake tube and it looks no leak, but really old. Can people help me figure out the problem? Other than that, the car runs great.
    52,773
    what kine of plugs did they use, and did they check the gap?
    what kine of mechanic doesn't stand behind their work?
  3. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    It sounds like some issue related to the spark plug wiring - spark plugs (shouldn't be as you've eliminated this option), spark plug wires, or ignition coil. I think the most likely cause is the spark plug wires as it was running fine prior to changing the spark plugs, which would require unplugging the spark plug wires and moving the wires (which could have caused a break in the wires/connectors). On most cars, these should be replaced at about the same interval as the spark plugs: about every 100k. On my 2004 Ford Focus I had similar problems and replacing the spark plug wires cured the problem.
    It might also be worth disconnecting and reconnecting the battery on the car to reset the ECU. If your old plugs had a really large gap, the computer may have adjusted the timing to compensate and now with the correct gap you're getting misfiring.
    If you use a code reader, is there an error code showing?
    #3 Kevin_Denver, Jul 6, 2016
  4. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    Have you double-checked the connection of the of the ignition coils to the plugs, and the wiring harness connections to the ignition coils?
    Was anything else changed or pushed around while you changed the plugs? If so , also check those. For example , have you rechecked all the surrounding connections to things like the mass airflow sensor?
  5. JC91006
    16,933
    8,643
    Has the car actually died? I would look at cleaning the throttle body and do a reset of your 12v battery by disconnecting for a few seconds.
  6. Purple Penguin
    Thanks for your reply, I will go back to check the wire.
  7. Purple Penguin
    The actually died once while driving up hill. I learned by then not to step hard on the gas pedal uphill. If I climb the hill slowly, there is no problem.
    Thanks for your response.
  8. Patrick Wong
    18,210
    6,517
    Prior to the spark plug change, did you have an acceleration problem?
    Did the problem occur immediately after the change, or did the car operate OK for a while before the problem started?
    Have you purchased fuel since the spark plug change, and did the problem start after the refueling?
    How long have you owned the car, and were the spark plugs changed at 120K miles (which is the normal service interval)?
    What is the brand and spark plug type that was installed? Do not think that all spark plugs are alike. If the correct NGK or Denso iridium spark plugs were not installed, that may be causing your problem.
    Is the check engine light, or any other warning light, on?
  9. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Is the Check Engine light on?
  10. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    1. Is it a correct assumption that these problems presented immediately after the plug change?
    2. What type of plugs were used?
    3. Were any other components replaced?
    4. Are there any codes? Do you see any indicator lights on the dash signifying there is a problem?
    Since someone else did this work for you, I believe they should be willing to diagnose and fix the problem. All of the suggestions you're seeing are good, but they require your effort, when I would assume it was an error on the party of the mechanic that resulted in this problem. Their problem, their effort is how I typically think.
    My best guess is that the plugs are either the wrong ones, incorrectly gapped, or the harness was damaged. But it should be on your mechanic to figure that out. Good luck!
  11. Purple Penguin
    I bought the car at 150 K, so not sure whether spark plug was changed around 120K or not.
    It was running fine without the acceleration problem before the plug change. And the problem occurred right after the change. But the shop owner change another set of 4 without additional charge and saying that it might be coincident that the problem occurred.
    I have no idea about how cars work, and no idea about the plug brand or type. I will go back to the shop and ask owner to check the brand, and also the wire connect the plugs.
    Thanks for your reply.
    Robert Holt likes this.
  12. JC91006
    16,933
    8,643
    So what made you decide to do this plug change if the car was running fine? Unless someone showed you proof the plugs were old and affecting the car, I wouldn't be messing with them.
    From what you're describing it actually sounds like a problem with your HV battery, but that would produce a warning light.
  13. Purple Penguin
    Also the "Check Engine" light is on. But it was on for a while for unknown reason. I found sometimes it will go off after a full tank, then turn on again. After a few times of re-fueling, it stays on. I am not sure whether it is related with the plug or not.
    Overall, I like Prius, the only I have with the small car is its safety features: looks too small light o be safe.
  14. JC91006
    16,933
    8,643
    Well.....that's something new. Maybe you have an emissions problem...like a bad MAF sensor, bad A/F sensor. Read the codes to the car......
  15. Kevin_Denver
    581
    425
    Denver, CO
    Agree with others, best course of action is to have the codes read. It will be hard to diagnose without this. Many auto shops/stores will do this for free. Once you have the code(s) you can google it and see what the problem really is.
  16. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    The very first thing your mechanic should have done is read the code(s). Without doing that, it's like trying work blindfolded. If he doesn't have the equipment to check them, he has no business being in business. You can get the codes read for free at most auto parts stores (Advance Auto, Pep Boys, O'Rielly)
  17. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    CEL/MIL being on totally changes the game, as others have noted.
    1. Was the light on before the spark plug change?
    2. Did you get the codes pulled? You can have the mechanic who did the work pull the codes, or an auto parts store will do it for free. Those codes should enlighten you as to the cause of your actual problem.
    Once we know the codes, we can more accurately recommend the correct course of action.
    My money is on a damaged harness. Anyone wanna take me up on that? :D
  18. Purple Penguin
    Thanks for your reply! I will have the codes pulled and get back to you.
    Here are the codes the mechanic listed for me:
    P0102 - MAF or VAF A circuit low input
    P0113 - IAT sensor 1 circuit high input
    P0456 - EVAP Emission control system leak very small
    P3190 - Fuel Air metering Auxiliary Emission controls
    Do you have any suggestions for what to do next? Thanks.
  19. JC91006
    16,933
    8,643
    Maybe the mechanic got careless when removing the air filter housing, didn't disconnect the maf sensor and pulled up, stripping the maf sensor wires from it's holder
    You should check the wiring to the maf
  20. Purple Penguin
    Thanks for your reply, is it easy to change by oneself?
