Acceleration tips? Battery care?
Discussion in 'Newbie Forum' started by Angela Marie Green, May 17, 2017.
  1. Angela Marie Green
    Angela Marie Green New Member
    28
    Maryland
    Hello from Maryland!
    I've had my new-to-me 2014 Toyota Prius for one week now. Averaged 57mpg today. Enjoying it so far.
    What I dislike most is accelerating from a full stop. I tried flooring it until I get to desired speed, then coast or use cruise control. I also tried to fool the car by pumping the gas pedal, never letting the mpg stay near 0 for long. Does anyone have any insights?
    I also wonder how to best extend the life of the batteries.
    Thank you in advance.
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Drive it like a normal car, gas is inexpensive now. Don't give other drivers a reason to hate you for trying to eke out maximum mpg.
    RCO likes this.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I use about 3/4 of full throttle, until I get to speed then cruise control. I want to not hold up other traffic.
    Internal heat seems to be the enemy. Use A/C when you are hot as the battery is hot too.
    If you have long downhills in your driving, (more than 600 foot drop) then consider shifting to B at the summit and using engine braking to not over heat the battery with too sudden charging.
    If you life where cabin temps get over 120F when stationary, consider sun shades.
  4. Angela Marie Green
    28
    Maryland
    Good point. You know, if I'm in the slow lane, I should'nt have to let a bunch of stressed out commuters tell me how to drive. I actually thought about putting a "student driver" magnet on the bumper. :)
  5. Angela Marie Green
    28
    Maryland
    Ok great. Sunscreens and AC. Tomorrow I will try the 3/4 full throttle and shifting to B. I haven't done that yet. Thank you!
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The problem is that they don't blame you, they blame the Prius. Now in some areas, all Prius drivers are targeted as inconsiderate slow pokes, no matter what speed they are driving. Please help our image by driving normally when in traffic.
    Thankfully, MS drivers see so few Prius, they do not recognize us, so we have less hate to contend with.
    1 Prius in 1400 drivers.
    RCO and Former Member 68813 like this.
  7. Angela Marie Green
    28
    Maryland
    Ok. I understand.
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  9. Angela Marie Green
    28
    Maryland
    The links are very helpful. I appreciate it.
  10. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    When you try out B (just to see how it works) you will find that the harder you brake, the louder the engine gets. This surprised me when I tried them out near Asheville, NC.
    Also B and Cruise Control do not mix, if you find you can't set CC, perhaps you are accidentally in B.
    (They happened to me, why not warn new owners?)
    RCO likes this.
  11. Angela Marie Green
    28
    Maryland
    That's kind. I will remember your advice and heed your warnings. :)
  12. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    Personally I try not to put the car into Power mode, eg. red line on the Hybrid System Indicator display when I accelerate. Beyond that I simply drive the car as normal, as was mentioned earlier. I just let the car computer do its thing so to speak. I used to watch the scores when we first bought the car but that drove me nuts trying to maximize them.
  13. Angela Marie Green
    28
    Maryland
    Thank you so much for that. I amost got into an accident yesterday cruise controling down a windy road. I figure once I get my routine down, I'll be able to relax behind the wheel again. I will try your way and see what happens. :)
    Former Member 68813 likes this.
  14. Angela Marie Green
    28
    Maryland
    And yes, I will see what the manual has to say.
  15. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    1. Power mode.
    It won't cost you money, and it's awesome.
    2. Some people here coast into stoplights (checking surroundings first , esp. rear view mirror), and may not always have to come to a full stop if the light turns green in time. I consider this an advanced...or maybe intermediate level maneuver....be safe.
    RCO likes this.
  16. Angela Marie Green
    28
    Maryland
    So awesome. That's the level I want to get to. i'm doing pretty good so far. 39 miles to work this morning at 63mpg average. Maybe I shouldn't fear power mode so much. It does charge the electric battery. Thanks so much for your response.
    RCO likes this.
  17. PriusNeckBeard
    376
    211
    Cincinnati
    No problem.
    Also, Power Mode doesn't charge the battery.
    Braking, because of stoplights and such does.
    As to fear of Power Mode....why ?
  18. Angela Marie Green
    28
    Maryland
    Well, now that I know it doesn't charge the battery, all it does - aside from speeding up the car - is burn gas. That's what I'm trying not to do.
    Prius from Dad and bisco like this.
  19. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Old wives tales I am still spreading:
    Back before the 1980's almost all cars had carburetors, which mixed gas and air largely due to air speed. This process was very approximate and to protect the engine once you got above 75% throttle, it started really adding much more gas than was needed to burn, just to cool the mixture. The buzzword is rich, too little gas is lean. Since the 1990's almost all cars have fuel injection, which adds fuel based on the mass or weight of the air. It still slightly enriches the mixture above 75%, but it is no longer the 'dump all the gas in you can' scenario it was when I was growing up.
    Anyway, this is why I was not recommending full throttle for best economy.
    Carburetor - Wikipedia
    Fuel injection - Wikipedia
  20. bisco
    52,790
    congrat and welcome! nothing to add to all the great advice above, all the best.(y)
    Angela Marie Green likes this.
