Accelerator Pedal
Discussion in 'Gen 3 Prius Technical Discussion' started by Susan4ET, Mar 2, 2010.
  1. bisco
    52,863
    can't argue with that, probably will never happen. did it ever get caught on the floor mat?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Never. And I tell you what: that little 1.5 did a great job getting us over the mountains, and with good mileage to boot. I average 55 mpg going over those passes.
    Tom
  3. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    Agree too. The only reason I got down there and wiggled things around was to see the accelerator and brake pedals because of the recall and all the other talk going on. I never looked at the 2007 I had and can't compare them now.
  4. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Who pushes their pedal to the floor??
    CHP officers.
    _H*
  5. bisco
    52,863
    point taken. moral? while you're down ther checking the pedals, make sure you have toyota floor mats clipped in place.:)
  6. bisco
    52,863
    not too shabby for non diesel.:rolleyes:
  7. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    Too bad I didn't include that tidbit too. One of the first things I noticed with the new car was that the drivers floor mat retaining clips were not installed. This happened with my 2007 Prius too. After the floor mat recall issues you'd think the dealers would do this one first thing. Anyway, I found the plastic bag with the retainers in the below-floor trunk storage. I ripped it open, poped them into place, hooked the mat on and then pulled the mat forward as I seated the mat on the floor to be sure the clips were fully engaged and couldn't easily slip up and off the hooks.
    BTW, when this recall/bulletin was issued it applied to my 2007 Prius but I was lucky because I had no floor mat interference at all. However, the recall/bulletin indicated Toyota would be developing a better retention for the carpet then the hooks--which to date it still hasn't. Personally, I don't know that I care. The hooks seem to have worked and are working fine on both cars. I haven't once to date found the mat moved around or off the hooks.
  8. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    I also see no problem at all.
    Please refer to attached picture for RHD JP Prius pedals with Toyota official floor mat.
    If a third party floor mat makes interference with the accelerator pedal travel, that's a problem.
    Ken@Japan
  9. bwilson4web
    16,540
    Did you take a photo?
  10. qbee42
    18,058
    3,081
    Northern Michigan
    Ken, I see your problem: your pedals are on the wrong side of the car!
    Tom
  11. bisco
    52,863
    clips have always worked for me, anybody see a better idea on another car? velcro? i hate that tearing sound!:eek:
    2 people like this.
  12. Tande
    Tande Active Member
    556
    339
    Mich.
    Yep...Same with my 2005...
  13. vegasjetskier
    vegasjetskier New Member
    269
    29
    East Coast of Florida, USA
    Yes. My Volvo had two posts that stuck up out of the carpet. The mats had two holes that friction-fit over the posts. This area was raised up, as were the edges of the mats. Any mud, snow or water you tracked in was trapped in the mats and they were easily removable. They never slid anywhere in my car (they couldn't, even if you tried).
  14. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    Or "pedal to the metal."
  15. strawdog18
    strawdog18 New Member
    Brooklyn, NY
    Can someone provide a straight forward explanation of how the Gen II acceleration system or pedal differs from Gen III and would possible explain why James Sikes's problem with his 2008 would not happen with my 2010 prius?
    I'd like to provide some type of ease of mind for my parents concerned about my recent purchase.
  16. Politburo
    Politburo Active Member
    971
    208
    We don't know what James Sikes's problem was, so I don't think anyone can answer your question.
  17. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    Interesting. Shortly after I got my 2010 Prius I ordered and received official Toyota floor mats, complete with clips. To tell the truth, the clips aren't all that unusual - both my old 2002 Civic and the 2008 Sienna we run here both had them.
    In any case, clips got installed along with the floor mats. And, given the attention given to recalls and floor mats back in January, I was really careful at installation to make sure that everything was engaged properly.
    So, weekend before last I got out the hose and washed down the car. Took a look inside, thinking about a vacuum cleaner, and noted that one of the clips, but not both, had disengaged.
    Put it back on and haven't thought about it until now. But I must have been running for a few weeks like that without noticing, waiting, I guess, for the other clip to let go.
    Sounds like a better clip system might be in order.
    KBeck
  18. qbee42
    18,058
    3,081
    Northern Michigan
    The Gen II and Gen III systems are very similar. I consider the Gen III as safe as the Gen II, which is to say very safe.
    You won't have James Sikes' problem because you are not James Sikes.
    Tom
  19. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    My dealer didn't install the hooks, just left it in the glovebox.
  20. Tande
    Tande Active Member
    556
    339
    Mich.
    Yes, Interesting.... I know on my 2010; once the mats are correctly engaged, I have a He!!/of/a/time disengaging when I want to remove them...:confused:
