Accessories for plugin
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Sanjath, Nov 5, 2012.
  1. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    I am planning to buy all weather mats for 2 rows and cargo area. I am guessing I should buy only those that are marked for plugin. When I click the link at the top, I see a weather tech cargo mat for prius, would that work for plugin? I also see trunk cargo tray, which mentions plug-in. I am not sure if "tray" means, it is non flexible one.
    Any other accessory that is recommended?
  2. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    I purchased the Husky units (front, 2nd row and trunk liner), designed for the PiP as well. Much cheaper, especially if you use the right coupon codes.
  3. Frank Perkins
    Frank Perkins Member
    129
    66
    Fairfield, Connecticut
    Coupon codes?
  4. stearicom
    stearicom Member
    81
    26
    I have the WeatherTech floor liners from my 2012 and they fit. But, there cut out for the gas door for the regular Prius. The cargo floor liner fits no problem.
    I would only purchase things specific to the plug in only floor mat wise.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  6. Electric Charge
    545
    133
    Syracuse, NY
    I always get mine via Auto Anything, since they offer the largest discounts. If you register here, you will also get 4% cash back. The same site also lists the Auto Anything coupons I usually use. I paid $199 for the entire set, and received a $29.99 discount, which was the cheapest option at the time.
  7. thepc28
    thepc28 New Member
    24
    SF Bay Area (East Bay)
    Carid.com has the husky mats for $106 for the first and second row. I'm not sure how much the trunk liner cost. Husky makes a prius plugin specific mat (no gas cover release).
  8. Electric Charge
    545
    133
    Syracuse, NY
    With the cargo liner, the total would be $196 @ CarID (assuming there is no tax/shipping). IMO, the cargo liner is worth it, especially since the batteries are right underneath the trunk floor.
  9. thepc28
    thepc28 New Member
    24
    Did your prius come with the "carpeted" trunk liner? I'm worried that having a hard trunk liner will make it harder to access the storage compartments below. Some company makes canvas liners that line the entire trunk area, but i want to see it installed in a prius before i buy it.
  10. Electric Charge
    545
    133
    Syracuse, NY
    I put the liner on top of the carpet. There isn't much space to access, so it was never really an issue. That said, I have the same liners in my Toyota RAV4, which has tons of space under the floor, and don't have any problems accessing it.
  11. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
