Accident in Prius, Engine would not shut off
Discussion in 'Gen 3 Prius Main Forum' started by dhs, Dec 17, 2010.
  1. dhs
    dhs New Member
    121
    Virginia, USA
    OP here....I probably did not hit the button for three seconds.....frankly, I am on my side, and was thinking car shut off....Car was in drive.
    Those are times when one does not think rationally.
    One would think there could be a sensor saying, if the car is on its side or upside down, engine is off.
    Basically, I climbed out of the car with the ICE running....
    Things I am concerned about mechanically:
    1) were the batteries damaged
    2) was the ICE damaged?
    Body work is not that bad (no estimate, but it is probably less than 5k...unless there is frame damage).
  2. Jolly Paul
    Jolly Paul Member
    162
    28
    If you describe the other car, we will keep our eyes open for the perp. :eek:
    I always thought an inexpensive external camera assembly (similar to back up camera) looking in 4 directions and feeding a few minutes worth of looped storage would be nice for just such an occasion.
  3. dhs
    dhs New Member
    121
    Virginia, USA
    Other car was a grey/silver Volvo XC 70...current model. Driven by a &$^$^T&* :mad:
  4. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Thanks for coming back :) So the rest of us should all know to hold down the power button for 3 second or maybe it's 5 i don't know but in a situation where i need to shut the car off i will press and hold the power button untill it shuts off and the ready light goes out.
    To answer your questions we need to ask you some.
    1. you asked if the batteries are damaged i don't see how the traction battery would be harmed. i'm not sure about the 12volt battery.
    2. You asked if the ICE was damages. If it was running while the car is on it's side did it run the whole time? Did you hear any weird noises/knocking comming from it? Did someone shut it off and how long after? Did you see any warning lights on the dash? i would think the bodyshop could make sure the ICE didn't get harmed. Also if they say it's fine just be sure to check all your fluids when you first get your car back and check them offten for a while, if some parts in the ICE didn't have oil pressure and are worn, i would think the oil level might show something with some driving.
  5. rpeek2
    rpeek2 Dry Ice Juggler
    149
    MidwayUSA
    As a point of information, my Kawasaki motorcycle has an integrated kill switch. If the bike is not plumb with the world the motor shuts down. Sounds like an inexpensive solution to a potential problem for any vehicle.
    I don't think the Prius has a closed sump system so If the ICE was running 45 degrees to vertical for any length of time something was possibly not being lubricated.
    The other fluids probably didn't stay contained either; There is reason for concern also.
    Ours not being a body-on-frame vehicle I can only imagine the additional clicks, ticks, and rattles, in the future, resulting from the accidental torque.
    Best of Luck!
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    If you do get it repaired I would be tempted to get rid soon after.
  7. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    No reason they should be. They don't care about up and down.
  8. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Yes, modern motorcycles have a tip-over switch that kills the ignition if the bike falls over. I'm astounded that a car with the sophistication of the Prius doesn't have one.
    With the ICE running on its side, the engine was most likely not getting an adequate oil supply from the crankcase pickup.:eek:
  9. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Your car is a 2010. Don't count on it being totaled...unless the garage says that your engine is damaged by running with out proper oiling of bearings....it's doubtful that it would cost more to fix then the cars book value.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    A tip-over kill switch is easier to do on a motorcycle than a car. Motorcycles, by their very nature, must stay mostly in column with apparent g forces, otherwise they tip over. This is why you lean a motorcycle when going around a corner.
    Cars, on the other hand, don't lean into a corner, so they experience significant lateral g forces during normal operation. A simple tip-over switch would kill the engine the first time you went around a corner.
    Obviously you could make one work. If you set it for 45° it would allow for 1 g turns, which should be plenty for normal street cars. You would also need some transient filtering to remove shock loads. All things considered, it wouldn't be that hard to do, but it would be more complicated than it is for a motorcycle.
    Perhaps part of the reason that cars don't have tip-over switches is that they have impact shut-offs for fuel. There may be an assumption that any accident sufficient to tip over a car would also trip the fuel cut-off. Obviously this one didn't.
    Tom
  11. PRPrius
    PRPrius Active Member
    327
    198
    This is why I believe a Roll-over sensor should be a standard feature on any car. With the roll-over sensor Toyota could allow the car to deploy the side impact airbags and also cut fuel and power to the HSD system.
    In this case, if the side curtain and side impact airbags didn't deploy, doest that mean that a Safety connect equiped Prius would not have contacted the Safety connect center automatically. It seems to me that the side impact and side curtain airbags will deploy only in a very narrow set of circumstances. However, having them deploy in a wider array of car accidents may reduce the number, type and severity of injuries. Nissan for example, will deploy the side and curtain airbags even on certain types of frontal collisions. I understand that the cost of replacing these airbags can be high. However, I would rather be alive and with just a few minor injuries than worry about paying a higher premium on my insurance.
    Concerning Safety Connect, I am very curious if this type of accident would have triggered an automated call to the emergency center. Without a roll over sensor this prius was unable to determine it was involved in a accident. Had the Prius determined it was involved in an accident, the powertrain woud have been shut down immediately. GM has really excelled in developing accident recognition hardware and software for their vehicles. I think Toyota would be wise to try and incorporate some of GM's and other european manufacturers accident recognition systems.
  12. fotomoto
    5,639
    3,815
    So. Texas
    If a tip over switch can be engineered for a generic $8K motorcycle, it can be put on a $30K car. 90 degrees is 90 degrees no matter what the vehicle.
  13. adamace1
    1,403
    193
    Charlotte, NC
    i'm sure the air bags go off/not go off to protect people. I highly doubt toyota tries to make them not go off to save the car owner money in an accident. I'm thinking it needs to be a certin g force inpacting the car at around a 90 degree angle from the from rear of the car. Part of the reason air bags take bigger accident to go off is air bags hurt people all the time. And they can cause more harm than good, thats why we have seen the warnings on the visors of cars for the last 12 years saying air bags can/do killl children.
    I'm sure Toyota has did their best in setting when and if air bags go off. Just think if someone was in a 10mph collision and the air bags go off killing one child in the car and breaking the neck of another child. The news would be all over it.
  14. ETC(SS)
    7,501
    Air bags are triggered by accelerometers. If your crash is outside certain predetermined parameters, then it's not a crash, and you don't need the airbags.
    Nothing new here.
    This technology is decades old and is the same for a $10,000 Aveo, as it is for das $33,000USD Wunderkars.
    Tip-over sensors have been standard on motorcycles for a while now too. Like I said before...I'm disappointed, but I'm not surprised. If I find myself inverted in a Prius, I'll try to remember the 3-5 second rule and hold my mouth juuuuust right.
    If you're worried about it...call the NTSB.
    I personally think that you should not have to figure out how to shut down a tipped-over car in the post-accident phase, but I'm sure some bed-wetting, skulking, ambulance chasing slimy attorney will fix this 'problem' so I'm not going to loose any sleep over it.
    Maybe Mama Yota can fix this when the Government makes them put "Vroom-Vroom" generators aboard so we don't squish any more kids in parking lots.
  15. dhs
    dhs New Member
    121
    Virginia, USA
    I have filed a report with NTSb. Is there a number or contact at toyota I can call? Frankly, my thoughts while on the side was how to get out of the car, and I need to turn off the engine, and I need to call 911. It is unreasonable to expect people to remember to hold the button in such a situation. I am not an idiot, but with the post accident adrenaline, i was not thinking clearly.
    Really, lost faith in the car. But, with Kbb saying the car is worth 20k+, it will not be totaled.
    I wish I stll had my Subaru..
  16. fuzzy1
    10,687
    I still have my old Subaru. How would it have handled this incident any better?
  17. dhs
    dhs New Member
    121
    Virginia, USA
    I could have turned ti off
  18. northwichita
    481
    102
    29
    Wichita KS
    So, how exactly was your car placed back onto the wheels?
    Attached Thumbnails [​IMG]
  19. adamace1
    1,403
    193
    Charlotte, NC
    Is it really that much to ask?
    To shut off a Prius hold down the power button for 3-5 seconds.
    To power off a Subaru, grab the key in the ignition turn counter clockwise(if you were looking at it from the passanger seat) unitll it reaches the off position, if you want to remove your key you need to put the car in park and the key will go one click farther and then you can remove it.
  20. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Great, yet another report that they have to chalk up to user error. It's not a matter of thinking clearly; you didn't even know about the 3 second rule as indicated by your OP in which you thought the power button was unresponsive and there was no way to turn off the car.
