Accidentally drained my 2010
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Johnsmith009, Feb 3, 2019.
  1. Mendel Leisk
    42,298
    It helps. I think after a serious drain a charger session is better, but meh.
    The old tried and true CTEK 3.3 are still available, and a bit more reasonably priced. P
  2. frodoz737
    frodoz737 Top Wrench
    4,795
    2,560
    33
    It does and he should...but I think we were just trying to get him out of the driveway and back in service ASAP.
    Mendel Leisk and mjoo like this.
  3. ASRDogman
    ASRDogman Senior Member
    8,052
    4,083
    I have a 2010 and stupidly left the lights on after driving in the rain.
    They were on for about 15 hours.
    They were off when I went out in the morning, it was still dark, and the car started up fine.
    Mine shut off automatically without anyway of setting it up to do that.
    I read in my owners manual the headlamp will shut off after a few minutes when the car is shut off.
    52,804
    but they stayed on for 15 hours?
    Raytheeagle likes this.
  5. Mendel Leisk
    42,298
    I left a door open for about 18 hours. That'll send it for a loop. They don't auto-shut off. Was reading 11.9 volts IIRC. Hooked up the CTEK, and it brought it back. But I swapped it soon thereafter, over 5 years old anyways.
  6. ASRDogman
    8,052
    4,083
    I miss worded that.
    I left them in the "on" position.
    They were still in the on position in the morning, of course. But the lights were off.
    I was surprised there wasn't any "dinging" when I opened the door to let me know
    something was left on.
  7. Johnsmith009
    Johnsmith009 Member
    124
    34
    Mississauga, Ontario, Canada
    Fixed, for now:
    Bought a smart battery charger and after about an hour and many, MANY times of the charger telling me "battery voltage under 10v after charging for 10 minutes, battery faulty, stopping" and me unplugging and replugging, replying "you die when I let you", it finally achieved a steady 12v, and I let it charge at 4A for about 15 minutes, then it started (but it wasn't enough for the parking brake to turn on? Good thing I had ebrake on).
    What I need to do now is return this barely functional charger (that needs to plug in the wall, no battery! Good thing I had a 100ft extension cable!) And get a better one.
    ... After I make sure it starts tomorrow morning.
    The second this thing started I cruised down a couple cities in pwr mode to increase my odds.
    Sorry for the lack of response, my phone was also low battery, and this parking isn't exactly close to home.
    mjoo, bisco and Mendel Leisk like this.
  8. ASRDogman
    8,052
    4,083
    You should let it charge on the charger for a few hours.
  9. Johnsmith009
    Johnsmith009 Member
    124
    34
    That would be nice if I had parking at home, as stated I don't. Currently have a temporary overnight permit to park in the street in case it doesn't start, and the owner of my parking space doesn't want any cables running through his yard. Which even if he did, the charger cannot be used in rain or snow, which I believe there will be a bit of both tonight.
    The important part is I got it out of the driveway on a Sunday. Tomorrow is a longer business day, so I could even buy a new battery if I needed to.
  10. Mendel Leisk
    42,298
    Yes that is something I was wondering about. Chargers are invariably plug-in. Street parking is a tough scenario.
  11. fuzzy1
    10,690
    Combining auto-off headlights with a headlight reminder dinger is pointless. Either one alone solves the forgotten-headlights-draining-battery problem.
    In fact, before DRLs, the auto-off feature could be turned into a convenient set-and-forget pseudo-DRL solution. I used it on two cars, including my 2010 Prius, before getting true DRLs on my 2012. A dinger with that would have been a significant annoyance.
  12. bisco
    52,804
    drive it as long as you can before parking for the night.
    scona likes this.
  13. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    In the past I've taken a car battery into the basement of my house and trickle charged it there where it's warm. Lead acid batteries charge better at room temperature. The prius battery is easy to carry. There are 10mm hex nuts on the terminals.
    Pixel XL ?
    Raytheeagle and Mendel Leisk like this.
  14. ASRDogman
    8,052
    4,083
    Mine is a Prius 2, doesn't have auto headlamps. Just running, then headlamps.
    I see NO point in auto lights. It's dark, you turn them on, it's not dark, don't turn them on! :)
    scona and Grit like this.
  15. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    Jump it
    Drive it
  16. Mendel Leisk
    42,298
    @mjoo beat me to it: remove battery and charge indoors.
    scona, fuzzy1 and mjoo like this.
  17. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I have auto lamps but never use it, never comes on when i want them to come on. Same for hvac, always manually on or off, never set to a certain temp. I’m just old fashion.
  18. fuzzy1
    10,690
    You list a 2010-II (it wasn't a Two that particular year, only later), just like my first Prius. That trim does have Auto-Off lights.
    Don't try to tell me it doesn't, because I still have the brochure and can upload a copy of the Features page showing it.
    Do note that Auto-Off is not the same as Auto. The former doesn't turn on with regards to outdoor light level but only on driver command. But that command could have been any prior trip, if the driver has not since manually commanded them off.
    Some of us want them on when it's not dark, for safety reasons, especially in our dim and rainy and perpetually overcast climate zone. Absent DRLs, Auto-Off is perfect for that. Turn them on once, leave them that way forever.
    #38 fuzzy1, Feb 3, 2019
  19. Mendel Leisk
    42,298
    Still, your troubles with the noco charger could be due to very borderline battery. It assesses battery, won't charge if it's hopeless.
  20. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    You don't even need to drive it. When you turn it on it will charge the battery. You can leave it sitting on the driveway for half an hour.
    I've had the 12V battery run out once (I was recording music onto the harddrive while in my garage, car was on two presses of the button without ready mode) and I jumped it with a 0-30V, 2A laboratory powersupply. Just hooked it up and that was enough to get the car to ready.
