Accidentally drppoed key on asphalt and lost the key retaining spring.
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by KilgoreTrout, Oct 26, 2018.
  1. KilgoreTrout
    KilgoreTrout Junior Member
    Central, KY
    So, I dropped my keys on the ground and the force caused the "smart key" to pop open and scatter its contents, most of which were easy to locate, however, there is a tiny spring which pushes the physical key latch against the physical key to keep it from sliding out that's gone missing.
    Anyone have any idea where I can obtain a replacement spring that will fit?
    lcastro likes this.
  2. ETC(SS)
    6,555
    Easy.
    Get a replacement [sic] "smart" keyfob from eBay and pop it open.
    Take the board and keylet from your broken fob case and put it into the new fob case.
    You'll have to do a little leg work to see which fobs are transwappable but Yota key fob thingies fit a broad range of vehicles.
    If you want to pay a little bit more and get one with a blank keylet, you use it as a spare, just like back in the good old days before keys got to be so "smart".
    Or?
    KO Just the Case for HYQ14FBA Smart
    Good Luck!
    KilgoreTrout likes this.
  3. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Spring from a pen, cut to size? Floppy disk flap spring?
    Otherwise, my silicone key fob case keeps everything in place. I have to remove it to take the key out.
    kithmo and KilgoreTrout like this.
  4. KilgoreTrout
    Central, KY
    I've tried modifying a pen spring, but the diameter is too large, unfortunately, for a good fit. I've got a copy of sim ant on disk needing a purpose, I'll see if that's a better fit.
    What model of silicone sleeve do you have?
  5. The Professor
    598
    809
    UK
    Excel
    I just got the sleeve on eBay for hardly anything. It's not branded.
  6. KilgoreTrout
    Central, KY
    Thanks!
    I ended up wedging the pen spring in sideways. It's now extremely hard to push, but it's not something I ever separate anyway.
    I'm going to pick up a silicon sleeve today.
    Thanks, professor and etc(ss)!
    The Professor likes this.
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,173
    2,213
    Taylors, SC
    Replacement cases are available on both eBay and Amazon.
