Accord Plug-in Gets Highest MPGe Rating above Energi, PiPl & Volt
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by hill, Feb 7, 2013.
  1. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    The charge rate is also highly dependent on the cathode and anode chemistry as well as aspects of mechanical cell construction. I'm not sure about the details of the cells they are using.
  2. hill
    8,799
    Heat too is one of the big variables that robs battery capacity over time. And charging means heat. So the Accord's 6 kW charging success will turn on its battery cooling system. That system will be more crucial turning on how stable the battery chemistry is that the Accord uses .
    What I just realized is that now that Honda has this plugin system that can run pure EV - it's likely they will upgrade their underwhelming plug in hybrid systems so they can give more bang to their other hybrids. This could be a really big win for the gen 3 insight.
  3. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Good point. I haven't seen any details of their battery temperature management system.
  4. acdii
    acdii Active Member
    1,124
    131
    So what gives it a higher MPGe with 13 miles over the Fusion with 21 miles? Does it get better ICE MPG?
  5. austingreen
    austingreen Senior Member
    13,671
    4,209
    Austin, TX, USA
    I think the insight is quite dead. It was based on the concept of going cheaper than a prius but almost as good of mileage. I don't think it will cut it with the prius c/aqua around. The Honda fit hybrid, not sold in America is better than the insight in many ways. An improved Honda hybrid system will help sell hybrid fits, civics, and accords. It will be a good thing if they get this right.
  6. bisco
    51,883
    has there been any independent testing? looks like everything in the article came from honda.
  7. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Assuming the Prius liftback will keep chugging along in sales for 10+ years, I think Honda may be one of the first to virtually copy the car with a full hybrid drivetrain. May see this in 5 or 6 years.
  8. david_cary
    david_cary Junior Member
    47
    17
    MPGe has to do with the efficiency of the EV system. It has nothing to do with ICE efficiency or range.
    It just means that you go further on your KW when you are running EV. Most cars are pretty close - usually around 100 MPGe but the Accord is a little more efficient than most. The 2013 Leaf is basically the same.
    Obviously the Energi would be in EV more often so for most people, it would still be cheaper to drive. But when the ICE efficiency is better, it will still be trip dependent. The differences are small but Honda will be best to 15 miles or so, then Energi will be good from 16-40, then Honda will be best again. We all know that highway the Accord is going to crush the Fusion in the real world.
    acdii likes this.
  9. acdii
    acdii Active Member
    1,124
    131
    So the Honda has a smaller pack, but can go further on it than if that same size pack were in the Ford? That makes sense now.
  10. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Would also add that mpge does not mean much unless accessories like HVAC and Stereo are also efficient.
    Nissan Leaf's new Bose sound system cuts energy use in half
  11. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Looks like the Volt is going to feel the heat from increased competition.
    DBCassidy
