Accurate MPG
Discussion in 'Gen 3 Prius Fuel Economy' started by C Clay, Sep 6, 2025.
  1. C Clay
    C Clay Member
    393
    78
    Lexington, KY
    2019 Prius
    L Eco
    I use a app called car scanner and it's kind of cool. It tells you what your gas mileage is on trips. I recently drove 1500 miles, the last two days nearly. I assume nothing is more accurate than just calculating how many miles you drove and how much Gas you put in the tank.
    If so, it looks like this app is easily 10 to 15% off. And even the instant calculation on the car – is off.
    Does that sound about right?
    This 40ish stretch is me running a crowded section of i40 likely having to slow down or speed up to maintain my spot- but most times around 78-81mph.
    I was thinking I was thinking I was getting 50+ on my 50 mile trip to work if I kept it under 60 on the highway- but I'm probably only getting like 44mpg.
    Why does it matter lol- because I want a truck! I'm cheap, and I see a Honda ridgeline (2017+) in my future. Maybe in a few more years if we find the the Ford Mavericks to be any good long term, that might be an option.
  2. PriusII&C
    PriusII&C Active Member
    432
    147
    San Jose, California
    When I bought my car new, I was curious about how accurate the MPG number shown on the dashboard. Over 10 - 20 fillups, my calculated MPG was always smaller than the dashboard MPG. It was about 5% smaller, not 10-15% off.
    I also did the same thing on my Prius C. The discrepancy was about 3% though.
    #2 PriusII&C, Sep 6, 2025
    C Clay likes this.
  3. BiomedO1
    BiomedO1 Senior Member
    4,550
    2,393
    Left Coast
    Don't know how your going to handle going from 40+mpg down to 20-25mpg in a Ridgeline. I have a very difficult time when I'm driving my 4x4 Envoy-XL at 18mpg. I figuratively have to stop at every gas station along my camping & fishing route.:(:rolleyes:o_O:LOL::ROFLMAO::notworthy::whistle:.
    Yes; the car's ECU calculations is overly optimistic and the odometer is displaying a few miles faster than actual travel. You can verify this by using GPS mapping over a straight level highway stretch of 5+ miles.
    #3 BiomedO1, Sep 6, 2025
    C Clay likes this.
  4. C Clay
    C Clay Member
    393
    78
    Lexington, KY
    2019 Prius
    L Eco
    It's better than my 2006 Ridgeline I had, seemed like I was getting about 12 mpg in town
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Using an abbacus will calculate mpg much accurate than that app
  6. ASRDogman
    ASRDogman Senior Member
    8,053
    4,083
    It's very sad people can't do simple math they should have learned in elementary school, or at home....
    Grit likes this.
  7. ETC(SS)
    7,516
    The G3's malfunction display is about as accurate as the nightly news.
    The fact that the errors CONSISTANTLY benefit the OEM is also noteworthy, but that's the difference between being wrong and being crooked, IMHO.
    As noted above, if you know how to use a trip odometer, and you're young enough to drive and pump your own gas then you can determine your cars real-world fuel efficiency with the phone that you almost certainly already have while you're gassing up.
    You don't even have to be connected to the cellular network!
    Just make sure that you have a calculator app on your smart phone.
    Fairly easy in KY.
    The last time I went through there (2 weeks ago) gas was well below 3$ a gallon - despite their $0.249 state gas tax.
    ASRDogman likes this.
  8. Mendel Leisk
    42,301
    Take the trip meters mpg and multiply by 0.93, and you’ll be close.
    Grit likes this.
