Acid bath and P0420
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sorka, Jun 7, 2016.
  1. JC91006
    16,936
    8,647
    If this works, this would be a good alternative to the $2000 that dealers charge. But I'm sure it's a band aid, like a rebuilt battery. I just want to know how long it'll last.
  2. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    That's the real question. If the cat has degraded due to overheating, then this won't help. If it's a combination of overheating and the surface being coated with metals contaminants then it would help some. In theory if the failure was due only to contamination, then following the procedure as outlined in the study would fully restore the cat.
    I did not follow the procedure exactly as I didn't have constant flow nor did I heat the water up to 150F. It started out at 115F and pretty much stayed there because it was in a black container out in the sun for the 6 hours.
    Here's an interesting forum post:
    (All Years) Catalytic Converter Citric Acid Bath P0420 - Subaru Forester Owners Forum
  3. JC91006
    16,936
    8,647
    We have another member that has a p0420 and doesn't seem to want to spend money to fix it.......this would be a good solution (LOL) for him.
  4. JC91006
    16,936
    8,647
    I wonder if the science has to be exact? Or if you can simplify it by saying, 1 pint of acid mixture to 1 gallon of water......for the people that are bad at math
  5. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    I think it needs to be close. If you don't do enough, safer, you'll get fewer miles before the efficiency falls below threshold again. If you go too far, you remove too much of the catalyst material. Think of the catalyst as a layer of clearcoat. If you get a scratch that isn't deep, it can be buffed out and the clearcoat is shiny again serving it's purpose. If you go to far and etch too much depth out of it, you've gone all the way down to the paint and ruined it.
  6. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    Another 130 miles today and still no DTC.
  7. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    Another 90 miles today and still no P0420 :)
  8. Patrick Wong
    18,210
    6,517
    If you have driven 360 miles since the bath without issues, then I would say this is a reasonably long-term fix. At least as long as the benefit provided by the traction battery "rebalancing" concept... :cool:
    What color was the acid bath prior to dipping the cc into it? Did the ash deposits visible in the cc disappear after the bath?
  9. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    Yes, the honey comb looked completely clean and like metal after the bath. The 8 gallons had a green tint to it after 6 hours.
    520 miles and counting.
    Patrick Wong likes this.
  10. Former Member 68813
    3,524
    983
    US
    this is so frigging cool. thanks for posting!
    even though your oil consumption is low, i would personally do a piston soak to fix it before it gets worse. google for piston soak or send me a PM.
  11. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    650 miles since the bath and still no ECL.
  12. JC91006
    16,936
    8,647
    I've figured out the simple formula for this solution, to mix a 9 gallon soak.
    Based on the information on the video provided, but using nearly pure citric acid and oxalic acid (both on Amazon).
    use 1.5 lbs of pure citric acid powder and 1lb of pure oxalic acid powder. That is pretty close (not exact) to what the formula requires for about 9 gallons of soaking solution.
    Who wants to get a group buy going on 5 batches of this stuff?? LOL I think that'll be about $5 per batch. Now only if I can find a container that will hold 9 gallons of this stuff without spilling over.
    #32 JC91006, Jun 24, 2016
    blaisep likes this.
  13. Patrick Wong
    18,210
    6,517
    A rubber trash can?
    JC91006 likes this.
  14. JC91006
    16,936
    8,647
    good idea, I have 2 of those kitchen cans around too. I'll be ready to test on Monday
    SFO and m.wynn like this.
  15. Former Member 68813
    3,524
    983
    US
    why 9 gallons? How about a smaller amount?
  16. JC91006
    16,936
    8,647
    The op used 8 gallons so I tried to get measurements close to 8. I don't know if 4.5 gallons would be enough liquid to soak the entire cat. I just wanted an easy formula. 4.5 gallons would still be easy, just not sure if it's enough
  17. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    2000 miles now and no ECL. I was going to smog it today but my wife didn't get home in time before the place I usually goto closes. The only places open tomorrow, Sunday, are more expensive than the places that are only open Monday through Saturday. So I might have to wait until next saturday.
    #37 sorka, Jun 26, 2016
  18. Patrick Wong
    18,210
    6,517
    What is ECL? Did you mean the check engine light has come back on?
  19. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    Sorry. That was a typo. It's supposed to be NO, not NOW.
    2200 miles and no ECL.
    I smogged it this morning. It's not due until 9/22. DMV should be mailing out the renewal in 3 weeks.
  20. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    2300 miles. Still looking good. So on Sunday, I went to the DMV website to pay my registration. It was early, like 88 days before it's due. It said that I was not eligible to renew online. It was about 3.5 weeks before they would have mailed out the renewal anyways. I smogged it Monday morning. This morning, two days later, I tried again on the DMV site and it let me renew!!!!!!
    So I'm officially past the the scare. A $20 acid bath saved me $1800.
    Noghri and blaisep like this.
