Acting funny at stops when running
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by exmetrodriver, Dec 26, 2014.
  1. exmetrodriver
    exmetrodriver Member
    124
    16
    Puget sound, Wa.
    My Prius tend to want to move/jump/jerk with the foot brake on. Is this normal when at a stop and the engine is running? Not sure how to better describe this.
    52,393
    not if it just started happening. maybe your brakes need work.
    exmetrodriver likes this.
  3. exmetrodriver
    124
    16
    Puget sound, Wa.
    I do have brake issues. Not sure but I think the rears are glazed. My brakes want to grab when slowing down to under 3 MPH. I thought it was the front brakes, but I'm sure it's the rear. I will be pulling my drums and swapping in a new water pump when the weather gets better. My post issue doesn't seem like it would be brake related. This seems more like transmission, or??? Just guessing at point. I don't pretend to be a mechanic.
  4. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    rear brakes probably just need to be adjusted for the grabbing at 3mph. the jump/jerking? I'd have to see it. my '04 ice would sometimes cut on and off several times when I was sitting at a stop. never did figure that out.
  5. bisco
    52,393
    how many miles on her? could be so many different things. you might need to see if any codes have been logged.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Are you new to a Prius?
    Because alot of times when the engine starts and stops it really bucks the car. If your new to it it can be quite disconcerting but its normal.
    You get used to it.
    2005 so probably lots of miles. Start doing some maintenance to her and you'll find it.
    As far as your brakes just bend over and look at the front rotors condition. Given where you live there probably all glazed and corroded up and maybe even gouged. If so when you roll out first thing in the morning they will really complain, grab and scrape till the rotors are scrubbed of surface rust especially if the car is not garaged. Take a tire off and measure the thickness of the pads especially the inside pad. If original brakes its probably time to do the entire brake system.
    Way past time. $$$$$$
  7. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Oh and don't touch the brake system yourself till you read up on it. Search. Its very tricky and if not done correctly its you and your car on a flat bed to the dealer to fix it. Seen hundreds of those here.
  8. Mendel Leisk
    41,906
    Transaxle issue?
  9. fuzzy1
    10,603
    If I read your history right, you just became a Prius owner six months ago. Is that correct?
    Are you aware that when slowing gently with regenerative braking, the regen kicks out and the car transitions to pure friction braking at 7 mph? I frequently felt this as a slight grab even on a new Prius. Could the 'grab' you feel be this transition, or is it separate?
    But at 130,000 miles, the brakes could easily be worn or rusty too.
  10. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Where does it say the car has 130000 miles?
  11. fuzzy1
    10,603
  12. exmetrodriver
    124
    16
    Puget sound, Wa.
    Thanks for all the feedback. I have 135K and have not pulled the brakes yet to inspect them. As noted above I guess it's normal for the car to "buck" when the engine starts/stops. So it sounds like I can do the back brakes myself, but due to technology the fronts may have to be done by a pro.
    edthefox5 likes this.
  13. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Be careful in the back too. The only thing I let a dealer due to my car is clean &
    Adjust the back brake. It was only $59.
  14. 69shovlhed
    2,170
    752
    Delaware
    if you have a small screw driver and flashlight, you could save $59.
  15. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Ah to be young again.
