Acting like a manual trans - engine connected directly to wheels
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Wecandothat4u, Mar 3, 2025.
  1. ChapmanF
    19,009
    Keep us posted on how long the $23 Amazon pump holds up. You can add the info to post #20 if it fails within the edit window. ;)
    It's a thing with gen 2 where a connection inside the underhood fusebox goes bad in that circuit, and people end up running a jumper wire. Search here for posts about that.
    Wecandothat4u likes this.
  2. Wecandothat4u
    Wecandothat4u Junior Member
    57
    Cambridge, MN
    Problem with trans p lock is in fuse panel. Not supplying voltage to blue wire in harness that goes to the trans ECU. Digging in to it now.
  3. Wecandothat4u
    57
    Cambridge, MN
    Just saw this. Yes that is the problem.
  4. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    On one of the Chinese sites I found pumps at an even lower price. About $12. They could be changed at least every day. ;)
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    <shrug> I have read quite a few posts about problems with aftermarket pumps, but very few about genuine Toyota pumps. Spent around $150? for OE almost 5 years ago with no problems since.
    The only cause for coolant "disappearing" is that there was-is a leak. The inverter system doesn't get hot enough to "boil over" (the ecu would shut the car down with a P0A93 code first)
  6. Wecandothat4u
    57
    Cambridge, MN
    Fair enough about the cheap pump. We will see how long it lasts. We have found no leaks in the inverter coolant system and will keep an eye on it.
  7. Wecandothat4u
    57
    Cambridge, MN
    We actually did better than running a jumper wire. We removed the fuse panel, turned it upside down, removed the cover and replaced the corroded pin with another one from my donor car. We now have 12V arriving at the trans ECU. The resistance tests pass as good and the problem has...... not gone away.
    #27 Wecandothat4u, Apr 10, 2025
  8. ChapmanF
    19,009
    Ooo, there's a surprising twist!
  9. Wecandothat4u
    57
    Cambridge, MN
    Well. I've been driving it anyway but now that the cold season is done, we're attacking the fact that the AC bleeds down in a day or two. We are replacing the entire heater/AC unit under the dash. WOW, that's a lot of work. But during the process we found this harness with one disconnected wire. Does anyone recognize it? And know where that loose wire goes to? The donor car doesn't have it.
    Maybe I should make this a different thread. Comments?
  10. ChapmanF
    19,009
    Fascinating. Looks aftermarket. Could the two white connectors mate with each other (I mean, if it weren't taboo, and all)? That would suggest it could be the kind of adapter harness sometimes sold to plug in between an audio headunit and the connector that normally plugs into it.
  11. Wecandothat4u
    57
    Cambridge, MN
    I think you might be right. Perhaps a bluetooth receiver. We're going to try putting things back together without it and see what happens.
    Brian1954 likes this.
  12. Wecandothat4u
    57
    Cambridge, MN
    Oh my. I forgot to follow up with this thread. Eliminating that short harness caused no problems.
    As for the P-Lock problem, I've just lived with it until today when we ran through the troubleshooting process again and found that running a jumper wire from the fuse panel to the ECU made it work. But I hadn't figured out how to get a permanent wire through the firewall and grabbed some conductive grease, put it in the connector at the fuse box and.... it now WORKS! I'll let you know if it stays working, but for now, I'm happy. Was it the grease? Was it just plugging and unplugging and fiddling with the plugs at both ends? I'm not sure, but like I said, it's working and I'm a happy guy.
  13. Wecandothat4u
    57
    Cambridge, MN
    That worked for a few days then failed again. This time we found the blue wire at the ECU was the culprit. Just move it a bit and it makes and breaks connection. Repeatedly! Again, some conductive grease on THAT connector and the problem has gone away. If it comes back again, I'll probably replace the entire plug. And if it fails again, I'll come back and post here.
