Active Grille Shutter Replacement/Repair
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by axle2152, Aug 2, 2018.
  1. axle2152
    axle2152 Active Member
    266
    210
    Atlanta, GA
    2018 Prius Prime
    I'll be honest, I feel like this is one of those good ideas that shouldn't have been pursued by Toyota (and other auto manufacturers). I'll quit my complaining there...
    Got the message that the grille shutters are inoperable, please see your dealer. MIL isn't on (yet) the DTC P05A0 is "pending"
    After I parked the car I looked in and the shutter appeared to be closed. While sitting in the driveway powered on the car and the shutters opened. It has been raining yesterday and today so I can't confirm or deny that there is a rock or some debris that it intermittently preventing the shutters from opening or closing or if due to the rain if there's some sort of electrical issue. Hopefully this weekend I can get a better look at things.
    Reading the thread about the TSB TSB: Debris stuck in active grille shutter (DTC P05A072) | PriusChat it would appear, if I am reading correctly, that the TSB does apply to my car...again.
    So would anyone know the approximate cost is for replacing the grille shutter? And secondly, has anyone had any success in repairing or keeping debris/rocks out of the grill shutters and stopping the message. They, like FCA (Chrysler), have made the message persistence as annoying as possible. However, I will give them that yes, if the shutters are closed the car could overheat and this isn't a chime and message over a tail-light...(yes my previous car had a CANN bus to the taillights and started getting a chime and message every time I pressed the brakes).
  2. Elektroingenieur
    2,515
    3,259
    Three Touring
    The repair procedure in the bulletin applies only if an inspection reveals “debris or witness marks where debris may have caused the grille shutter to stick open.” Toyota allows 0.8 labor hours for the job, which also requires three new parts:
    • 52618-47081 Lower Front Bumper Absorber (List Price $62.26)
    • 53019-47011 Radiator Shutter Sub-Assembly (List Price $309.65)
    • 88940-47011 Swing Grille Actuator Assembly (List Price $241.29)
    This might give you an idea of the cost, assuming your car has no emissions warranty coverage remaining.
    “P05A0” is an SAE DTC; the Toyota DTCs are P05A072 and P05A074, for which there are diagnostic procedures in the Repair Manual, available by subscription to techinfo.toyota.com. If the problem isn’t the one described in the bulletin, it’s possible only one of the Radiator Shutter Sub-Assembly or Swing Grille Actuator Assembly might have to be replaced, rather than both parts and the absorber.
    Frankiie and RCO like this.
  3. axle2152
    266
    210
    Atlanta, GA
    2018 Prius Prime
    @Elektroingenieur Thanks for the reply. Not sure why I wasn't getting the toyota specific DTC but might have been looking in the wrong place in the software. Anyway, I pulled the front cover off under the hood so I could look down in front of the radiator/AC condenser and while I didn't find anything stuck in the grill I did pull out a small stick that might have been moving around while driving down the road and cleared the DTC's. From there I haven't got the message again. I drove around while monitoring the "current position" and the +B voltage and observed the grill shutter opening and closing many times so I have to conclude that the stick was the problem.
    Since it is out of warranty for that I'll just be mindful to check and clean out junk that might cause the problem seems the shutters open and close as expected. Should the motor fail or something go wrong with the wiring then I'll have to do something about it. I don't think under normal conditions there would be an overheating condition but if you're driving around a city there might be a problem, I didn't observe any increased coolant temps anywhere but is something to watch as the car ages.
    Elektroingenieur likes this.
  4. Estela13
    Estela13 Member
    Just had this message come up on my 2017. I am at 134K miles they were refusing to cover it stating that my warranty ended at 35K miles. I pointed them to the TSB and they agreed it was covered so nothing out of pocket, I asked them what warranty I had after the replacement and they said up to 150K as stated online. So I’m covered for 16K miles, hopefully I don’t need replacement again.
    Frankiie likes this.
  5. bisco
    49,507
    isn't it sad that customers have to tell the dealers what's what? reminds me of the pharma ads that say 'you should tell your doctor'. what? my doc doesn't already know?(n)
    Mendel Leisk and Tande like this.
  6. hatcher8
    hatcher8 Junior Member
    32
    Lincoln Ne
    My 2017 Prius Prime displayed the "Grille Shutter inoperative See your Dealer" warning suddenly with 40K miles. The dealer wanted 150.00 to diagnose and 1,300.00 to replace it. I showed them the technical service bulliten T-SB-0319-17. They will cover it now under warranty. See page 2 of the attached bulletin. Your vehicle must be purchased and currently driven in one of the Eastern States listed for coverage up to 135K or currently residing in WA or CA for coverage up to 50K.
    On another note, I inspected my grill Shutter looking for any debris but could not see anything to pull out so I took a garden hose and sprayed the grill out, focusing on the corners where it hinges. 2 days later the warning signs and check engine light on the dash started disappearing. After three or four days of driving the warning signs have completely disappeared. View attachment T-SB-0319-17.pdf
    Frankiie, RayS NJ and krmcg like this.
  7. Sparkymann
    Sparkymann Junior Member
    Satsuma
    Two Eco
    I have a 2016 Prius Eco. I only get the alarm at highway speed. The shutter appears to open and close normally, I believe it may only be a malfunctioning limit switch in the actuator assembly. (if that is where it is located). I fail to see why the shutter assembly must be replaced if it is not damaged and moved freely. Also, why does the lower front bumper absorber need to be replaced. Is it destroyed upon removal?
  8. Elektroingenieur
    2,515
    3,259
    Three Touring
    If you have diagnostic trouble code (DTC) P05A072, but no debris or witness marks, or any of the other DTCs related to the grille shutter, then as I posted above, the service bulletin doesn’t apply, and you should follow the appropriate troubleshooting procedure in the Repair Manual (more info) instead.
    Depending on the diagnosis, some of those procedures—including the one for P05A072—do tell you to replace only the swing grille actuator assembly, rather than the entire radiator shutter sub-assembly.
    No, but there is an improved version of the part, listed on page two of the T-SB-0319-17 service bulletin (PDF).
  9. RayS NJ
    RayS NJ New Member
    Toms River, NJ
    Thank you for posting the TSB. When I got the "Grille Shutter inoperative See your Dealer" warning I brought it to my dealer and was advised the diagnostic error was different from the one in the TSB and it would be $756 to repair.
    I advised them that although the did not match exactly it should still be covered by extended warranty in the TSB. I argued that the TSB specifically stated if the warning is received and/or a diagnostic trouble code it be would be covered by the TSB.
    Dealer argued that the code did not match and would not be covered by Toyota.
    Called Toyota at 1-800-331-4331 and spoke with a "consumer advocate at Toyota who checked with a Warranty Manager and stated it should be covered. They said they would contact the dealer's customer relations manger and have them call me before days end. The dealer called me and stated they could not be reimbursed by Toyota because the code did not match exactly with the TSB. Again I argued that the and/or clause would apply and it should be covered. He stated he would get back to me , but I would not authorize any repair until it is resolved, because I would pursue it further with Toyota. About two hours later the Dealer's Service Dept. called me to advise me that Toyota is going to cover the cost of the repair.
    Thank God for Prius Chat and all of you for the help and info.
    RayS NJ
  10. tucatz
    tucatz Active Member
    501
    412
    Manzanita, Oregon
    Four Touring
    Toyota allows 0.8 hours Labor to complete this repair? It looks like an all day job to me!
    Valiant V likes this.
  11. kupow
    kupow New Member
    Bulgaria
  12. Frankiie
    Frankiie Junior Member
    Chino
    Thanks for the detailed TSB information.
    My Prius 2017; 80k miles just kicked in the same “Grille shutter incoperative” error . My guess is just some debris jamming the automatic shutter. After researching on this panel, I went to the dealer with the TSB warranty information, the dealer accepted it reluctantly, and will install all new parts under the warranty.
    Really appreciate all the information and help here.
  13. Wes_33073
    Wes_33073 Junior Member
    Got the code and error message in my 2019 Prius Prime… it was a frog stuck in the louvers! After clearing things out, I reset the code and the check engine light went away, but the error code is still stuck in there, marked as “permanent”. Not sure how to clear it out, or will it clear itself after so many miles?
  14. Wes_33073
    ok so not sure if it was miles driven, or on/off cycles, but this morning the code was completely gone from the DTC code list in Carista app. Hope this helps…
  15. Mendel Leisk
    38,735
    Wonder if 5th gen will still have these?
