TSB: Debris stuck in active grille shutter (DTC P05A072)
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Elektroingenieur, Jan 20, 2018.
  1. Elektroingenieur
    2,515
    3,288
    Three Touring
    On November 27, 2017, Toyota issued Service Bulletin T-SB-0319-17, “MIL "ON" DTC P05A072 Due to Debris Stuck in the Active Grille Shutter,” applicable to 2016 and 2017 Prius and 2017 Prius Prime cars sold in the U.S., but only if:
    • There is a “Grille Shutter Inoperative” message, diagnostic trouble code P05A072, or both;
    • Inspection of the grille shutter finds “debris or witness marks where debris may have caused the grille shutter to stick open”; and
    • The vehicle was made before the relevant production change, i.e., it has a VIN earlier than JTDKBRFU#H3050432 (Prius, Tsutsumi Line 1), JTDKBRFU#H3570595 (Prius, Tsutsumi Line 2), or JTDKARFP#H3039725 (Prius Prime).
    The countermeasure is to replace the radiator shutter sub-assembly, lower front bumper absorber, and swing grille actuator assembly with new parts, presumably of improved design. The bulletin includes work instructions but also refers to the Repair Manual for parts of the procedure. The repair is covered by the Federal, California, or state-specific emissions warranty, subject to its terms.
    At this writing, the bulletin appears to be available only by subscription to techinfo.toyota.com; I’m not aware of a free source.
    Mendel Leisk and pilotgrrl like this.
  2. Mendel Leisk
    42,295
    Technical Service Bulletin means a notice to dealerships, not a recall where owners are notified enmass?
  3. Elektroingenieur
    2,515
    3,288
    Three Touring
    That’s right, at least in the automotive context.
    A technical service bulletin provides information or explains how to fix a problem, and it applies only to vehicles that have the problem or meet the criteria stated in the bulletin. Owners are generally not notified about bulletins; you can think of them as supplements to the Repair Manual.
    In contrast, a service campaign or safety recall is an instruction to dealers to repair or inspect every vehicle in a certain group, even if it doesn’t have any related symptoms. Owners are notified about campaigns and recalls.
  4. Prodigyplace
    12,710
    11,848
    Central Virginia
    @Tideland Prius please add this to the TSB thread so I can find it if needed. :D
  5. Tideland Prius
    16,674
    RCO, Prodigyplace and Raytheeagle like this.
  6. bisco
    52,803
    i have never had a problem with my foam...
    Prodigyplace and Mendel Leisk like this.
  7. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    It depends where you're foaming, unless it's at the top of a glass.
    kithmo and bisco like this.
  8. Prodigyplace
    12,710
    11,848
    Central Virginia
    At the mouth? :eek:
  9. bwilson4web
    16,516
    Thank you!
    This showed up today but since I was driving pure EV, I continued my errands. I scheduled a repair and drove home. After getting a full charge, the message went away when I ran another EV errand. Hummmmm!
  10. bisco
    52,803
    probably frozen from the alabama rain;)
  11. Prodigyplace
    12,710
    11,848
    Central Virginia
    Is your Engine Block Heater cord though the shutters? The last guy that had that issue ended up with a melted Prius :(
  12. Elektroingenieur
    2,515
    3,288
    Three Touring
