Actual EV Range and Temp Relations
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by giora, Dec 8, 2013.
  1. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Well it's only 2.7 miles, so 1/10 of a gallon and probably not more than 1-3 times a year.
    Shouldn't discourage you from going out for coffee...;)
    Besides, I like your numbers.
    retired4999 likes this.
  2. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    Retired4999 :
    Just curious - in that -22 weather and anything close - what is your EV estimate saying ?
    I'm down to 9.6 for that read in the Boston area since we hit zero... Still getting an actual of about 11
    One interesting item - my car sat at the airport for 2 days. Cold when I left but it was a pretty warm 50 for my return.
    Yet my EV estimate remained at 9.6 so I'm thinking the estimate is purely based on the recent activity and not taking current temps into consideration
    keep the numbers coming
  3. markabele
    5,084
    1,782
    Nebraska
    I would agree. I think it's only on past usage.
  4. retired4999
    2,652
    627
    Eau Claire, Wi.
  5. retired4999
    2,652
    627
    Eau Claire, Wi.
    EV estimate 9.8
  6. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yep! Based on passed usage!
    9.8. EV is really close to what I am getting in this bitter cold!
  7. bisco
    52,693
    it occurred to me, as i was driving home tonite at 9 degrees, that my range hasn't dropped much since the temps dropped into the 30's or so. it's been around 12.5 for quite a while now. i wonder how that fits in with giora's graph?
    i think i did last winter, but i can't remember. i'll have to give that a try.
  8. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I think one of the main factors on actual range is charging temp.
    Mine is sitting outside, in my graph I included only trips immediately after charging with minimum difference between charging and driving temps.
    Are you charging in warmed-up garage?
  9. bisco
    52,693
    yes, it's unheated, but falls somewhere between the house temp and outside temp. for instance, when it was 9 outside, it was 39 in the garage. so, you maybe correct on the charging theory. i guess i would need a scangauge to measure the battery temp after sitting outside and then see how many miles i travel in ev. it would be interesting to know the battery temp after charging in a 39 degree garage, then after driving in 9 degrees for 1/2 an hour, then sitting in 9 degrees for an hour, and then driving another 1/2 hour.
  10. markabele
    5,084
    1,782
    Nebraska
    I think people overestimate how much charging heats up the battery. Just yesterday after charging there was only a 1 degree temp difference between the battery and the coolant temp (obviously after sitting overnight).
    Also, fwiw, a garage definitely seems to limit how low your range will go. I have yet to go below 12.4 for an initial range. And it's been below zero here.
  11. bisco
    52,693
    both good points. do you have any measured temp numbers?
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    Heated garage to 45 degrees f and my starting EV range was 9.8 this morning. So mine is still slowly going down.
    I did not record last years low point but if my mind can remember back that far it was about 9.6 for a low point.
  13. markabele
    5,084
    1,782
    Nebraska
    True. I think another big factor during the winter is your EV ratio. If you have a really high EV ratio, it will be much harder to have a large range. On the flip side, if you have a low EV ratio that means you have a lot of opportunities to use EV at it's biggest strengths.
    In other words...if someone has a EV ratio under 30% and have a range of under 10, they probably aren't maximizing their EV usage.
  14. bisco
    52,693
    i think it's going out for coffee at 20 below zero.:eek:
    giora and retired4999 like this.
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    Or it's winter in Wisconsin and -25 below and going up and down hills and going out for coffee for no reason, other than to solve all the worlds problems! :D
    Lourun likes this.
  16. markabele
    5,084
    1,782
    Nebraska
    I was more referring to the other people that have really low EV range and it's not near as cold as Wisconsin.
  17. bisco
    52,693
    i
    was referring to you.:sneaky: but i didn't know it hit -25!:eek:
  18. retired4999
    2,652
    627
    Eau Claire, Wi.
    I under stand that!
    Thanks! (y)
  19. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Pretty cold here and I use ICE to make heat!
  20. markabele
    5,084
    1,782
    Nebraska
    That should have only a positive impact on your EV range.
