Actual MPG
Discussion in 'Newbie Forum' started by DNG, Feb 9, 2013.
  1. DNG
    DNG New Member
    So I just bought a new 2013 Prius and was looking forward to seeing 50+ MPG or greater. I've been driving the car around the city for 3 days now and my average mpg is around 30. Anyone have any thoughts as to why this is? I don't really drive all that fast and even if I did it shouldn't be that low should it?
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Welcome & Congrats.
    There are countless threads pointing out the wide variety of MPG influences to new owners.
    With the car not broken yet and the fact that it is the middle of winter, you're facing a challenge right out the gate. Short trips are a major influence too.
    Basically, just give it time. Don't try to do anything special. Watch the MPG slowly climb up. And in the meantime, read up on all the comments made on the forum.
  3. pakhong111
    pakhong111 Junior Member
    31
    Usually in the winter, my '04 mpg decreases from 50mpg to 43mpg then in the spring the mpg increases again. Certainly the ethanol additive the refineries add during the winter months may be a factor as well as turning up the temperature in the car to stay warm/comfortable.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    How sure are you that you did not have usage from the dealer/other shoppers?
    Just wait until you would normally fill up, and reset all the trip meters, then focus on MPG, you need to be learning the controls and mirrors on the first tank anyway.
  5. bisco
    52,848
  6. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Yep. Or fill up now and reset the trip meters.
    If you truly want FE help, please answer Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new | PriusChat in this this thread. We can at least give you an idea of what you can expect.
  7. DNG
    DNG New Member
  8. DNG
    DNG New Member
    Where do you love though? I live in LA so its not really cold here.
  9. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    BTW, why did you expect 50+ mpg or greater?
  10. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Drive in echo mode helps.
  11. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    A new Prius will take time, in order to get great gas miles, it takes patiences, for a few months. I practice hypermiling techniques. Read tips in these forums, maximize tire pressure, plan to avoid excessive traffic and other things too. But I can already see some improvements. She is just starting to break in.
  12. JMD
    3,779
    1,282
    Ok video.
  13. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    No but you still have to deal with winter blend fuel. Temps under 60F have a pretty profound impact too.
  14. carnac767
    carnac767 Junior Member
    17
    Fredericksburg, VA
    I've taken my new 2012 prius IV on a couple of long trips and have averaged 50.8 MPG, using ECO mode. It's been fairly mild and I haven't needed either heat or a/c much.
  15. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    One very common reason for initial low mpg reading is not resetting the trip odometer from the dealership. Short test drives, idling in the parking lot while showing features, etc., will deliver very low numbers.
