Adapt USB thumb drive to AUX plug, will this work ??
Discussion in 'Gen 3 Prius Audio and Electronics' started by Jon Hagen, Oct 17, 2013.
  1. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    I love being able to record hours of music on a thumb drive and play it through the sound system of my 11 F150. My 10 Prius 2 has an AUX jack in the console. Will this or a similar device allow me to play a USB thumb drive through the Prius AUX Jack ??
    View Full Description
    USB Female to AUX 3.5mm Male Jack Plug Audio Converter Adapter Data Charge Cable
  2. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    This is short on detail. But I doubt they can cramp a USB controller and a MP3 WMA decoder D/A converter in that package and for 5.99.
    SAMSUNG-SGH-I747 ? 2
  3. Les_PL
    Les_PL Active Member
    317
    249
    Gdynia, PL
    I don't think it will work. There is no dedicated menu/controls for external device. IMHO the best solution is to carry additional MP3/WMA player connected to AUX. I have one Sony digital Walkman for that purpose, in addition my smartphone also is equipped with headphones outlet (not to mention Bluetooth connection which works OK).
  4. VicVinegar
    VicVinegar Member
    275
    53
    Northern Virginia
    Yeah you need software to read and play the files.
  5. Jon Hagen
    336
    136
    North Dakota
    Thanks guys, too good to be true LOL.
    I have a little VR 3 brand MP3 decoder / FM modulator that plugs in a lighter / power socket. That works pretty well to play MP3 music from a thumb drive through the FM radio.
  6. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    The ad says:
    "This cable can only be used in the car AUX hole with the decoding function
    Some cars AUX without a decoding function can only use MP3 devices"
    The Prius "AUX hole" is an audio input with no decoding function, and as the ad says, all you can use with it is an MP3 player that puts out a standard stereo audio signal.
  7. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    not likely at all !!!
    But newer Prius Gen III can directly play from USB I was pleasently suprised when I got the 2012 Prius 2 after the 2010 :)
  8. fuzzy1
    10,625
    2010s built after Oct 2009 got this USB function. It was one of the upgrades that I wanted when trading in my early production 2010 for a higher level 2012.
  9. szgabor
    994
    175
    Oceanside NY
    Thanks I did not know this I had a 2010 bought it in October 2009 (so it was built before that) but I am quite happy with this new addition in the 2012 I got.
