Add a 12v outlet
Discussion in 'Gen 3 Prius Accessories and Modifications' started by NewHybridOwner, Sep 9, 2022.
  1. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I am thinking of mounting my cell phone for use as a navigation device with a Scosche adapter attached to the driver's-side "quarter window," but that will require a long power cable to the 12V outlet under the center console. Has anyone added an outlet in the area to the left of the steering column near the instrument-panel dimmer? Where did you tap into a 12V line?
  2. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    Easy to do. Check ebay or amazon for a USB socket for a Prius.
    I tapped into the fuze box to a spot that wasn't used. Like seat heaters....
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    The fuse box in th kick panel area with a add a fuse cable.
