Add an additional 8Kw battery to double the range
Discussion in 'Prime Main Forum (2017-2022)' started by Banstro, Oct 25, 2017.
  1. bisco
    52,807
    should have got a lift back. 5 seats, spare tyre and a full hatch.
  2. Trollbait
    12,817
    Increasing the pack in the Prime by another 8.8kWh will likely cost as much as opting for those extras on a Volt, and cover some of the models' price difference.
    Convert it to a 50 mile plug in, and show Toyota how to package the battery pack.
    HPrimeAdvanced likes this.
  3. bwilson4web
    16,520
    Speculation is fine but we have today's facts and data:
    • 100 miles each way, daily commute - TSS-P is standard on the Prime
    • $0.21/kWh average New York electrical rate - reduces the advantage of a larger battery over gas efficiency
    • some ambiguity about a free charge at work, @Banstro
    I'm hoping @Banstro gets a chance later to provide more facts and data (i.e., $/gal regular, $/gal Plus, $/kWh.) If he hasn't reset the ODO MPG, we could calculate a 'back of envelope' ratio of electric to gas miles. But we'd really need his local electrical rate and gas prices to make a better economic model to apply against the big three:
    1. Prius Prime
    2. Volt
    3. BMW i3-REx
    #23 bwilson4web, Oct 31, 2017
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Yup. When the home brew Gen 2 plug-in mods were (somewhat) popular, there were no other options but to roll your own. Today, we have choices.
  5. Bigger battery pack would be nice, but as others were saying, we'll keep wanting more. Not to mention, battery technology has a LONG ways to go before it can provide 1000 miles on a single charge, without taking up space, and allow for quick recharging, and be cheap. Most of us need to keep waiting.
  6. Banstro
    Banstro Junior Member
    PA
    200 miles /day
    My PA rate is 0.0589 per KWH
    I have installed ChargePoint 32A charger in my garage
    At my work location I have free ChargePoint Level 2 charging and the car is fully charged in 1hr 50 mins to 2 hours. When I dont get the EV charging, I use the 120v outlets nearby in the garage which charges in 6 hrs. The car is charged till the time I am about to leave in the evening.
    I will never go with Chevy or over rated BMW.
  7. bwilson4web
    16,520
    Yes, the BMW turned out to be ‘delicate’. Having the Prime as backup works for me.
  8. RonMc5
    RonMc5 Member
    89
    73
    Santee
    True, but a really good mod would lower the normal battery 4" so it is at the bottom of the trunk. That way the new battery would not encroach quite as much into our luggage space (currently insufficient for an upright grocery bag beneath the tonneau cover! Now there is just tons of unobstructed empty space under there! Actually I'd like to see a mod that just shortened the pedestals the battery currently rests on. I have posted under-pictures elsewhere in this forum. Before you say cooling, the are two powerful blowers (one on each side fed for vents next to the rear seats) forcing air through the battery and (it appears from the plumbing) out the bottom of the car.
  9. Banstro
    PA
    I use the car primarily for commute and don't car much about the trunk space. If the additional battery would stay just beneath the tonneau cover that would be great as it would be hidden from plain sight.
  10. Trollbait
    12,817
    Not worried about cooling, but the fact that the well under the battery was designed for a spare tire, so is rounded and smaller than the current pack. Any modification to get it to fit in three will involve cutting out the sheet metal ledge the battery rests on, which will effect structural strength of the frame, or building a new case, and repackaging the battery.
    Cooling becomes an issue if you plan to simply 'slip' the additional battery into that empty space. Got to make sure enough air flow can be brought to it. The blowers are going to be running more often with any of the additional battery near the original. You've added more heat producing mass to a confined space.
    What about cost? I figure you will likely have to buy a totaled Prime to get the extra pack at this point in time. It will also provide parts for testing modifications to the car.
    If you are serious about this, I suggest reaching out to the people that did the plug in kits for the gen2 and gen3 for advice.
  11. bisco
    52,807
    just put the back seats down and put a wrecked tesla battery in there.
  12. Trollbait
    12,817
    I suspect the specific battery chemistries don't much up, meaning different voltages and amperages between the cells.
    Putting in a liquid cooling system would be the bigger hurdle though.
    Thinking about it, I believe some of the plug in kits did use lead acid batteries.
  13. Banstro
    PA
    so what would be a reasonable price for the OEM 8KW battery? If it will take me 5+ years to recoupe it then I don’t think it’s worth the upgrade.
  14. bisco
    52,807
    new, or salvage?
  15. Banstro
    PA
    Both...
  16. bisco
    52,807
    $5,000. and $1,000.
  17. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    If it turns a once a week visit to the gas station into a once a month visit, regardless of $ savings, would that be worth it? It would to me.
  18. Trollbait
    12,817
    The Prime hasn't been out long enough, or sold in the numbers, for the battery pack price to be public knowledge at this point.
    However, a replacement for the earlier generation Prii run around $1500 to $2000. Those are about 1.5kWh capacity.
    My guess is at least $5000 for a Prime pack.
  19. Banstro
    PA
    It all depends on your drive necessity like how many miles you drive a day and whether you get free charge up each way. If I had 25-30 miles commute each way, I wouldn't bother looking for an upgrade. I have 100 miles each way.
  20. bisco
    52,807
    new leaf is looking good.
