Add auto headlights to base model
Discussion in 'Gen 4 Prius Technical Discussion' started by ma171ac, Jul 5, 2018.
  1. ma171ac
    ma171ac New Member
    texas
    I've searched and searched and I can see that pre Gen4 this wasn't overly complicated with just replacing the stalk and running a wire or two. I can't seem to find any posts where someone tried adding this to a Gen4 model II that didn't come with the auto-on. Anyone know if i can do this or am i stuck with an aftermarket kit to do this?
    Thanks in advance
    Justin
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    You'd need to install both sensors as well. It would also need to be programmed, possibly needing a different computer or computer module - I'm not sure how they work.
    I suspect it would be better to upgrade to a version which has it already installed.
    Mendel Leisk and krmcg like this.
  3. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Don't do it, it's not worth the time/money/effort. Here in the UK we don't have an "OFF" position on the switch, if we did I would turn them off, I'm quite capable of deciding when to switch the lights on. They are very annoying, especially when going under a bridge where they momentarily come on, the driver in front thinking you're flashing them, Also they don't work well under dull conditions where headlights are a requirement, like when it's raining.
    #3 kithmo, Jul 6, 2018
    alanclarkeau and Mendel Leisk like this.
  4. Mendel Leisk
    42,205
    When I first heard about that I was in disbelief. Sometimes I think we're moving backwards. :(
    alanclarkeau and kithmo like this.
