Add BSM to XLE?
Discussion in 'Prime Technical Discussion' started by 200Volts, Jul 5, 2025.
  1. 200Volts
    200Volts Member
    439
    46
    Northern CA
    Can BSM be added to an XLE?
    i.e add 2 mirrors, 2 rear sensors and the rear control unit?
    Would this be plug and play, recognized on the canbus and just start working? Or is anything else needed?
    Thanks everyone!
  2. RandyPete
    RandyPete Active Member
    409
    171
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    BSM?
    #2 RandyPete, Jul 22, 2025
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    BSM, I guess blindspot monitor.
  4. 200Volts
    200Volts Member
    439
    46
    Northern CA
    Sorry, yes BSM = blind spot monitor.
  5. rjparker
    rjparker Tu Humilde Sirviente
    10,663
    6,695
    Texas Hill Country
    The usual answer is no, you can't just plug in oem parts and expect it to work. Toyota is bad about leaving out cables for options not initially installed and using different software as well. The easiest solution is to trade the car for a trim that comes with it.
    However there are aftermarket options that could be added but would not be as integrated.
    DIY BSM blind spot Monitoring system Prius prime | PriusChat
