ADD fog light on 2012 Prius 4
Discussion in 'Gen 3 Prius Accessories and Modifications' started by hbu, Mar 7, 2012.
  1. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    You need a lower grill that has the foglight openings in them to mount foglights. If your model doesn't have them, then another one needs to be sourced.
    SCH-I535
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Yes, The PIP has the exact same bumper, the only difference is the lower grill. The reg Prius has an all black grill whereas the PIP have the silver piece on it.
  3. Madmommymelinda
    Madmommymelinda Junior Member
    51
    Lexington, KY
    2014 Prius Plug-in
    Awesome! Thanks guys!
  4. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    May be we can just cut a hole on the original bumper grill of the prius and then install a Yaris fog lamps, do you think it is doable???
    #244 JayLn, May 9, 2015
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Yes but the holes would more than likely have rough / unfinished edges.
    Post pics if u decide to pursue
    VS980 4G ?
  6. xliderider
    8,140
    3,280
    Honolulu, HI
    You wouldn't have anything to mount the foglight housings to. You would have to fabricate some kind of bracket. Way too much trouble.
    IMO, much easier to get the proper grill with openings and mounting points molded in.
    WE0H likes this.
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    @xliderider, the mounting tabs for the actual fog light is part of the bumper, not the grill.
    VS980 4G ?
  8. WE0H
    WE0H Senior Member
    3,247
    528
    Does that mean he can take the Sawzall to the shiny black part and create the openings for the Yaris lights and screw that down to the bumper tabs?
    Mike
  9. Nobody123
    Nobody123 Member
    160
    33
    United States
    2015 Prius Plug-in
    From what I understand, there are 2 tabs that the lens assembly snap into. Then there's one self-tapping screw on the other side.
    The tabs snap into the bumper cover, and the screw screws into the grille.
    You could of course fabricate any and all of these yourself, but whether it will look as nice as factory depends on your skills.
  10. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    The edges is not a problem for me I bought a 16ft door edge guard from my friend who works for toyota for $85 and I have a lot of spare left so I can use it to the edges of the cut, and if you check my rear fender I just used the door edge guard too if you look closer I extend the guard thru the bumper, the front fender not installed , don't have time to do it yet.
    Check here:Screenshot by Lightshot
    sfv41901 likes this.
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Actually that screw goes into the bumper cover itself....not the grill
    VS980 4G ?
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    In these pics u can see the fog light mounted to the bumper without the grill
    VS980 4G ?
  13. Nobody123
    Nobody123 Member
    160
    33
    United States
    2015 Prius Plug-in
    Are you in the business of going around and correcting me without getting paid any money?
    If so, this is great. Please continue. I appreciate the information.
    Is there a difference between the Toyota foglamps and aftermarket foglamps in the extra mounting tab?
    I looked in the Toyota parts diagram for the part number for the screw, and I see that the Toyota lens assembly doesn't have the extra inner upper tab that does not bolt to anything.
    Does this also mean I can ride around with no grille?
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    The OEM & aftermarket fog lights 4 the Gen3 Prii all come with 4 tabs.
    Yes, the lower grill is simply cosmetic so if u needed to drive while the grill is out, u can
    VS980 4G ?
  15. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    He is contributing about this topic, no body cares here about you being right or wrong, unless you are famous? But now we know that the bumper has already a whole and we only need to get a drill so the circle will be perfect, and I called a junkyard and they said they are selling the bumper grill for $30 so I might buy it when I have a time and try it so I dont need to do it on my original grill.
  16. ncases
    ncases Senior Member
    609
    672
    Chicago
    I would rather be corrected than being sorry for what i did to my prius that is incorrect. ;)
    WE0H likes this.
  17. xliderider
    8,140
    3,280
    Honolulu, HI
    Just source a lower grill with the foglight cutouts already there.
  18. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    If anybody is interested, I have a new un-mounted fog light grill that I can sell, just shoot me a PM
    VS980 4G ?
    WE0H likes this.
  19. Nobody123
    Nobody123 Member
    160
    33
    United States
    2015 Prius Plug-in
    Has anyone painted the grille body colour? I recall seeing a Winter Gray grille, but I think only the upper strip was painted, and not the whole grille.
  20. ncases
    609
    672
    Chicago
    I installed cheap fog light kit from ebay and switch will stay on even when ignition is off.
    I realized that the 12V that feeds the switch LED came from the fuse box where it supplies the fog lights and that the reason why the lights remains on. So I revised by rewiring it.
    There are 3 wires the goes to the fire wall/ the black with white wire is the 12v that goes to the switch and the brown wire is the 12v back the to the relay. I snip the black wire which I don't need since I tap this wire to the bolt under the dash
    Here's the revise switch.
    Sleeves on for neat install.
