ADD fog light on 2012 Prius 4
Discussion in 'Gen 3 Prius Accessories and Modifications' started by hbu, Mar 7, 2012.
  1. ncases
    ncases Senior Member
    609
    672
    Chicago
    Now my switch will not lit when ignition is off.
    And it lits when headlight is switched ( tapped black wire to ground and 1 black/white wire to brown wire in the ECU. connect brown to brown and b/w to b/w wire. Problem solve!
    Thanks every one.
  2. JayLn
    JayLn Active Member
    248
    141
    Four Touring
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    They'll fit, but... it doesn't say what type of bulb goes in these lights. I'd bet they are H3 bulbs, which are kind of cr@ppy IMO. Also, those aren't CCFL halos, so they are LED, which in this type, aren't bright enough for daytime visibility. Purely for show at night.
    Prius chat member Cheizy has a good quality set on sale in the Private Sales forum than would be much better.
    sfv41901 likes this.
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I agree. They'll for no problem but it's a crappy projector with a crappy bulb.
    VS980 4G ?
  5. xliderider
    8,140
    3,280
    Honolulu, HI
  6. s2kinfinite
    s2kinfinite Junior Member
    Hello to all the Guru`s out there....I have a 2012 Prius 5 which comes with the OEM fog lights which I am considering upgrading these weak lights. I have two questions if someone could kindly advise and sincere thanks in advance!
    1) Can I swap out the the lights without removing the bumper cover?
    2) If I get a set of lights that only have the red and black wires, does anyone know the plug name or model number I can order a set without cutting and using my OEM Fog light plugs?
    #266 s2kinfinite, Nov 2, 2015
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Hello,
    Yes, u can access the fogs without removing the bumper.
    U will need to get a set of these
    H11 to 9006 adaptors & cut off the 9006 end & splice it to ur new fog light
    9006 Female Adapters
    Or u can get a set of empty H11 male connectors with terminals & crimp them onto ur new fog light
    Headlight Wiring Pins and Seals - Wiring Accessories - The Retrofit Source
    VS980 4G ?
    #267 sfv41901, Nov 2, 2015
    Dylan Doxey and s2kinfinite like this.
  8. s2kinfinite
