Add lights to the Cargo Area?
Discussion in 'Prius v Accessories and Modifications' started by yaksushi, Dec 7, 2014.
  1. yaksushi
    yaksushi New Member
    Louisville KY
    I've seen a few threads from people asking about lights in the cargo area of the v but no how to threads. Has anyone added cargo lights to their v that didn't already have lights? How hard of an install is it if you have?
  2. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    I put a round "stick-on" LED on the right side of my cargo area. It takes 2 AAA batteries. I use Energizer lithium batteries. In my previous RAV 4 they lasted about 2 years.
    You may have to use a better grade of double sided tape to keep it in place permanently. The area where you will place it needs to be cleaned well with alcohol before applying the light.
    This light's switch is the lens. Press to turn on and again to turn off.
    #2 Eric "v", Dec 7, 2014
  3. TMosh
    TMosh Junior Member
    30
    Spokane, WA and Mesa, AZ
    2013 Prius v wagon
    I have looked at this and just not done/selected what I want. There are a number of battery powered, small, bright LED lights that adhere by self-adhesive or small screws that could be installed and all you do is press on the center of the little fixture. There may be a problem with the adhesive failing in a really hot car (like in AZ in summer). I also found a small 12 volt 4 white LED light strip at Auto Zone, etc. that cold easily be hard wired into the existing switch. I could be easily mounted above the existing light and switch and come on with auto switch function or wired to manually come on with a small toggle switch using the power to the switch.
  4. TMosh
    TMosh Junior Member
    30
    2013 Prius v wagon
    This is what I am considering; but, am concerned the adhesive mounting will fail in a car that super heats when parked in sun. Any experience with that? We used the same light in several places in our RV; but, it never got too hot.
  5. yaksushi
    yaksushi New Member
    Louisville KY
    I'd like to put 2 lights in the square spots in the hatch. Have them turn on when the hatch is opened.
  6. sfprankster
    sfprankster Active Member
    444
    490
    Santa Cruz Mountains, CA
    Here's a set of LED's that fits into the rear license plate bulb cover.
    Rear Cargo Hatch Lights
    I have a set and it took about 10 days to ship. I haven't had the time to install them yet.
  7. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
  8. yaksushi
    yaksushi New Member
    Louisville KY
    Thanks has anyone installed this kit yet?
  9. Air_Boss
    4,259
    1,197
    New Yawk
    I''ve got it, know it fits, and am hoping for a translation of the detailed Japanese language instructions.
  10. yaksushi
    yaksushi New Member
    Louisville KY
    So you haven't installed it yet? Is there a wiring harness with the kit, or are you required to splice wires?
  11. Air_Boss
    4,259
    1,197
    New Yawk
    The two harnesses (lift gate and chassis) are nicely built, are shrink-wrap sheathed, and have the proper two-pin plugs to mate with OEM Toyota jacks.
    That said, the instructions for running the harnesses through panels and accordion sheathing between chassis and liftgate are in Japanese, which I am trying to get translated. I could wing it, but I'm not in a hurry to ruin anything.
  12. yaksushi
    yaksushi New Member
    Louisville KY
    I just ordered mine, not sure how long the shipping will take. Hopefully you will have your instructions translated by then and you will share your exp, thanks!
  13. Air_Boss
    4,259
    1,197
    New Yawk
    Shipping took three days from Japan. Translation is taking longer...
  14. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    I live in Las Vegas and keep my car outside a lot. So far the extra strong double-sided tape I used (after the original tape failed) has kept the light fixed in place in a very hot 'Vegas summer.
  15. yaksushi
    yaksushi New Member
    Louisville KY
    Good to know! What tape did you use?
  16. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Not a Prius V, but see here for ideas.
  17. yaksushi
    yaksushi New Member
    Louisville KY
    Nice!
  18. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    Yakoma,, nice lighting work.
    Yaksushi,, I used SCOTCH brand heavy duty double sided tape to hold my LED light in the trunk. Got it at Lowe's.
  19. Yakoma
    470
    125
    sss
    Eric, I agree, but it wasn't mine...belongs to ucsbwsr
  20. Air_Boss
    4,259
    1,197
    New Yawk
    No joy on translation. Were you able to get yours installed?
