Adding 1000w inverter question
Discussion in 'Gen 2 Prius Accessories & Modifications' started by JC91006, May 11, 2014.
  1. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    Make sure it is DC rated. The solar industry would be a good place to start. A real 80 amp DC fuse will not be cheap...there are a lot of stereo type fuses that I would not recommend.
  2. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    I would say Maxi fuse, but really any fuse of sufficient rating, that you can also get a fuse holder for, that the fuse holder will accept the same size wire you are using.
  3. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    Mine is from a solar array. It was 50.00 or so, with the holder.. But I harvested it from a used system (free)
  4. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    A maxi and holder would work fine also, go to a heavy truck dealer and they'll have it in stock, cheaper than an a auto parts store
  5. priusrust
    priusrust Member
    205
    74
    MA
    I have a Gen 2 ....would like to install inverter directly to 12 volt battery. Since I know nothing about electronics, I am unable to decipher the best option when people discuss this issue and have different opinions. I'd love to find a definitive 'how to' video.......or a place that installs them. I'd prefer not to muddle through myself only to see my prius vaporized in a explosive mini-mushroom cloud from some ill-advised hook up. Thanks!!
  6. Kaptainkid1
    Kaptainkid1 Active Member
    308
    247
    Los Angeles
    I did my inverter hook up this past few months and have already used it during a 24 hour black out.
    Here is a video write up with parts list.
    Here is my version of this mod.
    The only change to my gen mod I would do is hook up the 80amp fuse switch to the end of the hook up cables attached to Prius 12 volt battery cable and not attached to the cables attached to the inverter. I thought if breaker trips because overload I wanted easy access to trip back the switch. So putting closes to end of the quick disconnect would be the ideal placement.
    I was able to run a LG fridge full size, cable modem, TV, computer and few room lights at full load. Also the GenTrans switch was a safe way to hook power to the house without disconnecting the city power source for rest of the rooms not connected to Generator Inverter.
    20200512_194917.jpg IMG_20200418_164349.jpg 20200410_152753.jpg 20200410_151803.jpg
    SM-J737T1 ?
    bat4255 likes this.
  7. Minima Domum
    Minima Domum Member
    84
    147
    Adelaide, Australia
    i-Tech
    As others have said, the fuse it to protect the wire, not the device which (should have) its own fuse.
    ANL or MIDI fuses are a good option, the glass ones common in cheap "audio wiring" are useless, as are the plastic resettable circuit breakers.
    EDIT: I just realised that comment was 6 years old lol... Click 'next page' next time whoops
