Adding a beep when the interior lights are on?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DavidinNevils, Feb 25, 2026.
  1. DavidinNevils
    DavidinNevils Junior Member
    42
    Georgia
    Has anyone done something like this? (I'd want a several minute delay for when loading and unloading. A cloth in the back was caught in the hatch latch - preventing the interior lights from turning off, and that resulted in a dead battery. Not a good situation.) This text is from the Brave Search AI-critter. "Adding a beep when the interior lights are on is not a standard factory feature on the 2012 Toyota Prius, and there is no official, simple method to add this circuit through user-accessible settings or button combinations."
    "However, a custom electrical modification can be implemented by a qualified technician or DIY enthusiast. The most practical approach involves:
    • Sensing the interior light circuit: Tap into the wiring that powers the interior lights (typically the dome light or map lights).
    • Using a relay or electronic module: When the interior lights are turned on, the module triggers a buzzer or piezo beeper.
    • Mounting the beeper: Install a small, low-volume beeper in a discreet location (e.g., near the fuse box or under the dash) to avoid excessive noise.
    • Power source: Use the vehicle’s 12V system, with proper fusing and grounding."
  2. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    Yes what of it all available . Most folks are not trying to add more noises .and isn't their s buzzer going off wen door open at park and ignition off etc ? It goes off when the door fully shuts or the hatch lid fully closes so a towel caught should not allow full closure and light and buzzer on ?
  3. DavidinNevils
    42
    Georgia
    I don't really understand what you are trying to say.
    Our 2012 makes no "noises" when the doors are open, nor when backing up.
    In order to avoid a dead 12v battery - due to human error, a buzzer - with a delay (long enough to cover common lengths of time to have the doors open - so it's silent then), but after that to warn of an undesired drain - makes strategic sense.
  4. BiomedO1
    BiomedO1 Senior Member
    4,637
    2,434
    Left Coast
    How are you going to hear the buzzer, inside the car, when you walked away from it?????? Haven't you just introduced another drain on your 12V battery? What happens if that device malfunctions, another parasitic draw on the battery? Wouldn't it be easier to just look at the car, to see if the interior lamp is ON - obviously easier if it's dark out.
    Please complete your thought on how this is suppose to work when your outside your car and the buzzer is inside your car or do you mean to install an external buzzer - loud enough to disturb your neighbors?
  5. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    In your 2012 Gen 3, does car not refuse to lock when all the doors are not closed properly like on the Gen 2? If it does, then the easier way to get the beeping is to lock the doors every time.
  6. DavidinNevils
    42
    Georgia
    I'm not the primary user and this is to keep the primary user from getting stranded. (It is what it is.) The long-delay buzzer-button will have to be loud enough to draw attention. It won't create a meaningful draw because it won't be ignored for long.
  7. DavidinNevils
    42
    Georgia
    I doubt that the primary user will remember to do that.
