adding a solar panel to the P2 12V battery
Discussion in 'Gen 2 Prius Accessories & Modifications' started by groar, May 2, 2012.
  1. groar
    groar X-Frenchy: very
    Toulouse, France
    Quickly searched the forum but didn't found any thread showing it done. If I mis-searched, thanks to direct me to an existing thread.
    Sunny days should be back during next weeks, so a project is coming back in my head...
    On the net there are several threads where people are adding a small solar panel to the 12V battery of an HCH. I did so with a low grade amorphous 13W panel to my Mégane (old turbo diesel) through a charge regulator that I configured so it charged the battery only while the alternator was off (glides ICE off).
    The goal is to set and forget it. The charge controller has a small LCD screen so I can verify it, but I don't think to put it on the dash, as it contains a thermometer that should be at a temperature close enough the the charged battery. Also that little LCD screen doesn't love sun at all : after a couple of minutes under direct sun it becomes black for a couple of hours...
    Would it be OK to do the same to the Prius 12V battery ?
    Is setting the charge controller to limit the charge @13.7V would be OK ?
    Of course it will not charge the HV, but it would be sad to let the charge controller and the panel in the garage...
    Denis.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  3. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    The Prius Gen2 uses a DC Converter to charge the 12V auxiliary battery using power from the HV battery when needed. I do not see much point in using a solar panel for this application. However I use a solar panel mounted on the inside of the rear hatch window to power a series of fans to cool down the cabin. I have PHEV kits which need cooling down.
    See this link http://priuschat.com/forums/prius-p...-dc-dc-overheating-issues-10.html#post1472841
  4. cwerdna
    12,544
    2,123
    SF Bay Area, CA
  5. lopezjm2001
    1,146
    407
    Sydney Australia
  6. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    Can you take an image and share plz. I have wondered about 12v parasitc condition as well?
