Adding amplifier to Prius Prime?
Discussion in 'Prime Audio, Electronics, and Infotainment' started by spencetimm, May 20, 2020.
  1. spencetimm
    spencetimm Junior Member
    SF Bay Area
    2020 Prius Prime
    Hi all,
    I am getting ready to install a small amp and upgraded speakers in my Prime. I have a few questions for those who have done it:
    1. The amps I am looking at all have line-level inputs; do I really need some sort of line output converter if I'm getting audio from the factory head unit? I have heard some say that the factory head unit does some equalizing so a LOC will remove that but I'm not sure if its necessary or not. If I can just use the line-level inputs on the amp, that will save a bit of wiring (extra power wire and ground).
    2. Has anyone used the factory speaker wiring? I understand that the dash speakers and door speakers are wired in parallel, which means I need a 2-ohm minimum amp if I am going to use 4 ohm speakers in the dash and door. Otherwise, I could run new wiring, but this seems like much more of a PITA.
    Thanks for the input!
  2. spencetimm
    SF Bay Area
    2020 Prius Prime
    To update this - I did not end up installing the amp. I started to try to route the power wire through the firewall and decided it was too much effort for the benefit. I did install new speakers in the front doors (in addition to the upgraded dash speakers) and that made somewhat of a difference. Next, I'm thinking about replacing the head unit with one that has a little more power than the factory unit.
  3. rain27
    rain27 Junior Member
    2018 Prius Prime
    I’m using the factory speaker wire to the doors. I tapped into it just before it’s wired in parallel with the dash speakers.
    I wasn’t able to get good sound from the factory head unit, so there may be some equalizing there, maybe even volume dependent...not sure.
    Running power wire was a pain but can be done. If you attempt to do it, there’s a dimple in the grommet next to the factory wiring going through the firewall. If you can manage piercing that, you can get wiring through.
    If you find a way to run speaker wire through the door, report back. I haven’t seen anyone run their own speaker wire through the molex in the door. I want to though.
Loading...
