Adding another remote to my Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by RMB0001, Aug 17, 2022.
  1. RMB0001
    RMB0001 New Member
    Hey I'm trying to add another remote to my 2005 Prius. I tried to do it without a scanner but couldn't because it was being rejected on the keyless entry but the transponder worked fine. Now I bought an XTool D8 and have no idea what to do. Help would be appreciated. Thanks!
  2. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    First things first. If you're trying to add a fob to a Prius with SKS (Smart Key System aka keyless entry and start) you need a fob with a silver logo. The silver logo key also needs to be brand new as in never been added to any car before.
    If you have these things, can you use your Tool D8 to see how many keys are currently registered to the car?
  3. RMB0001
    RMB0001 New Member
    Oh it needs to be a new key... I have a used sliver key from another car that was scrapped in the past. I managed to get the transponder working but not the keyless entry.
  4. dolj
    dolj Senior Member
    8,633
    4,387
    Correct, with a non-virgin fob that is all you can get working.
  5. RMB0001
    RMB0001 New Member
    Alr lmao thanks I got it working
