Adding door lock sensors?
Discussion in 'Prime Main Forum (2017-2022)' started by jgurley, Aug 29, 2020.
Tags:
  1. jgurley
    jgurley Junior Member
    42
    17
    Anyone ever tried adding a electrified passenger side door pull to a base model? I'd bet the harness is there. Maybe your can enable it the OBD interface? Same question for the hatch? Really the only feature I miss.
  2. jgurley
    42
    17
    Sorry. I searched inside Priuschat and found nothing, but google showed me the proper search terms. I assume by the time I finish reading the long thread I'll know my answer.
  3. Salamander_King
    Salamander_King Senior Member
    10,975
    8,868
    New England
    The answer is NO. I don't think it's an easy mod to convert 1 door SKS to 3 doors SKS. Actually, for Prius PRIME, XLE and Limited are 4 doors SKS which include the fuel port lock. If you find any information on the conversion, please let us know.
    49,492
    if history tells us anything, the harness is there, and you need antennae and maybe ecu
  5. kenmce
    kenmce High Voltage Member
    1,530
    507
    NY
    You are thinking that all the necessary hardware is in there and just needs a command to start working. If this is untrue, or you can't find the command, you could try transplanting a full set of hardware from a junker and then running the signal wires to the working lock in hope of slaving the new lock to a working one.
  6. ChapmanF
    15,618
    My history with Prii has mostly told me Toyota isn't prone to running many more wires than the trim level they are building will need.
    On a couple of occasions, I've been motivated enough to pull the dash apart or fish through the firewall to add something that wasn't in my trim, but often I just reconsider the project at that point.
  7. bisco
    49,492
    you could very well be right. someone added sks to the hatch and passenger door of a gen 2 or 3, and all the wires were there iirc. still a big job though, it is detailed here somewhere.
    i seem to remember things like power mirrors and cruise, etc. where the wires were there, but i'm old and mostly senile
  8. ChapmanF
    15,618
    It's worth mentioning that the wiring diagram typically does show what wires are or aren't going to be there in a particular build. I've used this drawing as an example before:
    You can see you'll have the wires with (*6) in a car with the Touch Tracer display, or the ones with (*7) in a car without, and the wires with (*8) if the car came with nav, or (*12) if the non-display radio, and so on, with the legend for the numbered *s being up in the top corner there.
    The nice thing about that is you can find out what kind of a job you're in for before crawling into the car and pulling panels off.
