Adding footwell lighting to v two
Discussion in 'Prius v Accessories and Modifications' started by gafortiby, Sep 22, 2016.
  1. gafortiby
    gafortiby Member
    98
    58
    Colorado
    My 2012 v two does not have the footwell lighting, and I suspect that many other years have the same "problem."
    However, to my surprise, the harness and wiring are already present. The only thing left out from the factory is the light bulb. I found the wired connector on both the driver and passenger side.
    Searching various threads here on Priuschat, I see that the Lexus light is a direct fit. Lexus part is 81080-22040. However I think it might be weird if all the lights on the car are amber and bright white in the footwell. So I wonder if I should get the Prius version instead. Looks like the Prius version is 81080-48010.
    Footwell & Glovebox OEM LED Lighting Change | PriusChat
    Here's the kicker though. The Toyota and Lexus version sell for the same price. :p
    bostonbruins8703 and fotomoto like this.
