Adding LED Footwell lights to Prime Plus
Discussion in 'Prime Accessories and Modifications' started by BChoAss, Jun 18, 2021.
  1. BChoAss
    BChoAss Junior Member
    34
    22
    CA
    2019 Prius Prime
    This Definitely won't be a plug and play option, and some splicing would be involved. Would it be possible to use the following: PT413-42130 2013 - 2018 Rav4 footwell light kit below for the Prime?
  2. citiprius
    citiprius Active Member
    241
    237
    51
    2018 Prius Prime
    FYI, when the vehicle is in Park, the footwell light will be at its brightest state. Once it vehicle is in D, it will be dimmed
    BChoAss likes this.
  3. BChoAss
    34
    22
    CA
    2019 Prius Prime
    @citiprius Thanks for the heads up!
    I'm assuming I would need to connect this to the ambient light relay.
  4. BChoAss
    34
    22
    CA
    2019 Prius Prime
    @chickenhawk Question, I was hoping if you could be help me find the exact wires to hardwire this Rav4 footwell kit to my PRIME.
  5. chickenhawk
    chickenhawk Member
    261
    95
    CA
    I think on my Highlander I hooked up aftermarket LED footwell to the headlight signal, that way when headlights go on the footwell lights will go on. There was no auto dim mode that citiprius talks about.
    @BChoAss curious why did you buy the RAV4 kit ? is it the same part number as the Prius Prime?
    BChoAss likes this.
  6. chickenhawk
    chickenhawk Member
    261
    95
    CA
    a.jpg This is the Kit from Amazon i put for the Highlander.
    BChoAss likes this.
  7. BChoAss
    34
    22
    CA
    2019 Prius Prime
    @chickenhawk I appreciate the reply. I personally chose the RAV4 kit as it was already OEM assembled and included OEM white LEDs which was the look I was aiming for.
    I was looking though some previous footwell wiring posts and stumbled across this from @Elektroingenieur he commented:
    "The European manual for the same accessory tells you the wire colors at the left and right footwell lights.
    The Electrical Wiring Diagram and the diagram of the Footwell Light Circuit in the Repair Manual (available by subscription to techinfo.toyota.com) show that unswitched power (pink or gray) comes from the 7.5 A DOME fuse, but not through the DOME CUT relay. Ground (green or white) is connected to the FSPT terminal on the Main Body ECU, where it is switched by a transistor."
    Prius Prime door light wire | PriusChat
    Do you possible know which wires he is mentioning?
    If you look at my attached RAV4 footwell kit photo above, you can see that there is a YELLOW and GREY wire that needs to be tapped into two wires mentioned above.
    #7 BChoAss, Oct 11, 2021
  8. chickenhawk
    chickenhawk Member
    261
    95
    CA
    If you look at the directions, for example this driver side is located behind the panel that you remove above the gas/brake pedal. Pin 1 which is grey is the positive side and the white wire is negative. It is a wire that has nothing connected to it, look at the picture and compare. They want you to do wire tap to connect your led harness to the car wiring.
    You can hook up your harness up to the battery terminals to make sure it lights up, looks like the yellow will be the positive and the grey will be the negative/gnd.
    BChoAss likes this.
  9. BChoAss
    34
    22
    CA
    2019 Prius Prime
    Attached is a footwell light wiring diagram for anyone interested with a Prius Prime PLUS or LE
    I'll be uploading photos once I get around installing my RAV4 Footwell kit above.
