ADDING MORE HYBRID BATTERY MODULES
Discussion in 'Gen 3 Prius Technical Discussion' started by RHFACTOR, Jul 5, 2013.
  1. RHFACTOR
    RHFACTOR Junior Member
    I was wondering about the feasibility of adding a few more battery modules in parallel for increased wattage and better electric capabilities? I've seen used ones for sale on eBay and wondered if anyone had already done this? All comments appreciated!!! RHFACTOR
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    get a pip.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    1) without serious safety precautions, you can be killed by the wattage you already have. All the safety gear Toyota installs assume you stay outside of the battery case.
    2) it will be up to you to re design the charging circuits if you change the batteries to be charged. 2 or 3 companies do this, but it is non trivial.
    Enginer | Solar Powered Prius Plug-in PHEV Conversion Kit with Lithium-Ion | Hybrid
    Plug-In Supply | Plug-In Conversions for the Toyota Prius
    As you will see, most rely on plugging in the additional batteries rather than redesigning Toyota's inverter.
  4. prius_in_pa
    prius_in_pa Junior Member
    208
    27
    The concept sounds simple but I don't think it is. If you put two batteries in parallel, you'll need some sort of safety circuitry to protect the batteries in case on of them goes dead. The dead battery will potentially become a short circuit for the live one. That's my guess.
    I would imagine that the battery is not cheap, so you probably would want to add a charging circuit so that you could re-coup your investment sooner. Just a thought.
    PS: The extra battery will not increase wattage but will increase kilowatt-hour.
  5. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    Well this is done by some people but unless you are an experienced EE with related field experience (high power inverters/converters, batteries etc) with the right tools and willing to risk your car during development ... this is definitely not a DIY .. I am MS in EE but no experience in these fields so I would surely not try something like this from scratch.
    Just my 2c...
