Adding more Prius batteries
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by wwiggins, Apr 14, 2012.
  1. wwiggins
    wwiggins Junior Member
    26
    Kentucky
    I saw on YouTube a lady who had two or three prius batteries from salvage that she put together to extend her EV range. Where do I search to learn how to do this?
    Wade
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Um, apparently Youtube. (we might have been able to give more help had you linked the Youtube clip)
  3. wwiggins
    26
    Kentucky
    It wont let me without posting 5 times
    Its entitled nikki drives prius on youtube search.
    Wade
  4. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Here is the link -
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    I believe this is the same person that blew up her packs in a charging thermal runaway incident. The car was written off by her insurance.
    http://priuschat.com/forums/gen-ii-...lectric-vehicle-mod-under-way-bristol-uk.html
    There are a few people out there that have been able to make such a setup work, but it takes VERY close attention to detail with multiple failsafes. If you are going to go to such trouble, use lithium.
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Yep she blew her Prius up and has now moved onto a Leaf. What she doesn't know about EV's isn't worth knowing. I believe she's also a journo for various EV related websites and publications too - international and UK based.
  7. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    For those who care, the incident is buried in the above thread but can be found here:
    http://priuschat.com/forums/gen-ii-...e-mod-under-way-bristol-uk-32.html#post885615
    http://priuschat.com/forums/gen-ii-...e-mod-under-way-bristol-uk-33.html#post887261
    http://priuschat.com/forums/gen-ii-...e-mod-under-way-bristol-uk-33.html#post889411
    It makes one respect the amount of engineering for safety that Toyota must've done (into the hardware and software of stock, unmodified hybrids), which clearly seems successful.
  8. wwiggins
    26
    Kentucky
    Ok, so who has done this successfully? And has others who replicate it successfully? With the pip out it looks like someone would reverse engineer it as a retro fit for non plug in hybrid prius.
    Wade
  9. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    I don't know of anyone who has done multiple NiMH packs in a III. There are a few, mrbigh and nwpriusplus, that have done it in a II. Aftermarket kits are available: Enginer.us, PluginSupply.com.
    To put it gently, if you have to ask if it is possible to add NiMH packs to make your III into a DIY PHEV, you are at least a year away from having a safely working system.
  10. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    you have a 2012 car... they sell a plug in version for a reason... it would possibly end up costing you more to make a plug in than to just buy it from toyota...
  11. Braddles.au
    Braddles.au DEFAnitely using an EBH
    295
    99
    Canberra, Australia
    Hi Wade
    The Australian company NilCO2 has several packs that can be fitted as a supplement to the existing standard hybrid battery. Convert Your Hybrid into a Plug-In Hybrid Electric Vehicle have had displays at the Canberra EV festival for at least the past 2 years.
    They have a K40 pack that can be installed and removed without upsetting the car or diagnostics and gives 40km (25 miles) of range. These can only be charged from the mains and can't be charged by the Prius. (c.f. 24km ~ 14 miles with the PiP)
    Their bigger packs like the K140 replace the 1.2kW HV battery with a 14kW battery, plus changes to Prius computer messaging and uprated rear suspension struts.
    Quoting from an email I got from NilCO2, "K140 pack users are recording <0.6 litres/100km at average speeds of >75kph including highway peaks of >100kph. Urban use has clocked prolonged (>80km from a single charge) primarily EV mode consumption down to 0.3 litres/100K."
    NilCO2 also do solar roofs (for non-sunroof models) but don't expect to never plug in again.
    Australia doesn't quite have the Magnussen-Moss provisions, so car manufacturers can blame everything on the unauthorised bumper sticker you fitted instead of acknowledging fault. However, I understand that the K40 kit (which doesn't replace the HV battery) has never caused issues with Toyota Australia.
  12. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Why buy a brand new 2012 $$$ car when you can get a used Gen II and convert it using kits which have proven themselves? Using a 2012 PiP for this would be nuts right now IMO.
  13. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Now that's interesting. Will give it some serious reading.
  14. wwiggins
    26
    Kentucky
    The pip is not in KY yet. Wont be until 2013.
    So I can't just go and buy one.
    Wade
  15. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    I'd imagine you could probably get one from an out of state dealer.
  16. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You CAN go and buy one, you are just going to have to go farther than Kentucky.
    Should still be cheaper and more reliable than making your own.
    (if you follow Paradox's advice, I will sacrifice and trade my 2009 for a 2012 straight across)
  17. wwiggins
    26
    Kentucky
    I was under the impression demand was out pacing supply, and these cars were being ordered, not just sitting around on blots for any length of time. Also there are no states adjacent to mine selling them. It would be a long ride to discuss buying a car.
    If i did purchase it way out of state would my local dealer have any reservations about servicing it under warantee?
    What is the closest pip lot to me?
    Im in western KY next to Evansville Ind.
    Wade
  18. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  19. solarPiP
    solarPiP Junior Member
    Dallas, TX
    just for your consideration:
    I'm in dallas, tx and had mine shipped about 1k miles from Tuscon, Az.
    Az won't be getting anymore, btw.
    they financed in the shipping charge, $1200, with the car purchase.
    not terrible.
  20. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    The K40 pack is a 4kwh Enginer kit. You can buy these on EBay and have it delivered to Australia and install it yourself if you like DIY stuff. Nilco2 is an authorized dealer and installer of Enginer kits.
    Enginer | Solar Powered Prius Plug-in PHEV Conversion Kit with Lithium-Ion | Hybrid
    Enginer PHEV | eBay
    Nilco2 told me that the K140 pack is home grown technology. Most PHEV kits in the USA if not all of them do not replace the OEM HV battery.
