adding mud guards
Discussion in 'Gen 3 Prius Accessories and Modifications' started by pauln64, Nov 22, 2011.
  1. pauln64
    pauln64 Junior Member
    77
    Macon, GA
    where's a good place (and cheap) to buy mud guards?
  2. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
  3. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    On my Gen II they clearly help keep spray off the area immediately behind the wheels, particularly the front driver and passenger windows!
  5. harry r
    harry r slowly turning green
    122
    NW of chitown
    Got mine from prius chat accessories shop . Got the smaller ones and like them a lot. Heard the larger ones can effect mileage and did not like that possibility. Easy to install.
  6. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I have the larger ones, and if there is any effect on MPG it's miniscule as I couldn't measure it.
    Overall, I think they do a good job at keeping some spray off the car. However, with all the rest of the road spray from other cars, I don't know how much difference it really makes.
  7. k9frog
    k9frog New Member
    88
    sullivan co ny
    i got my set at the prius chat shop, and they for sure help keep the spray off the car, and there a snap to install oh and i got the smaller size set
  8. Mendel Leisk
    42,276
    This is the first car we've had in over 30 years that didn't have stock or readily available mud flaps, and...: don't really miss them. Nice clean look.
    FWIW, the flapless wheel is almost a mudflap anyway, goes down quite far at the back.
  9. tonyl
    tonyl Junior Member
    27
    Like (dustoff003) said buy them here it was areal good price win I got mine.
    Saw no mpg diff. and the car stays cleaner on the dirt roads here in SE AZ.
  10. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    674
    179
    Vancouver, WA
    +1 :cheer2:
  11. pauln64
    77
    Macon, GA
    any drilling involved or just bolt on?
  12. Tideland Prius
    16,673
    One of them requires drilling (I can't remember if it's the front or the back set). Super easy to install. You just need a power tool.
  13. wick1ert
    1,311
    183
    Delawhere
    I managed to install on mine without drilling. I used a little pressure on the screw driver and they went right on. IIRC, I did remove the tires for the rear ones to allow for easier access.
  14. Superdrol
    Superdrol Member
    399
    32
    Where I live snows. How does the mud guards hold up with a lot of snow jammed in the wheel well ?
  15. Tideland Prius
    16,673
    I guess drilling is the wrong word but yes that's what I did too. I just put the screw on the power tool and installed the mudguard.
    It holds up fine but you'd be wise to knock the snow out (no point carrying all that extra weight)
  16. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Loose rocks on the roads I drive have ripped the little oem deflectors off. I don't think it's worth the effort or money to put mudguards on. :(
  17. wick1ert
    1,311
    183
    Delawhere
    Gotcha. I know the instructions said to drill a small hole, but it's not really necessary as we know. I didn't even use a power tool (unusual for me) just a little continual pressure and it worked. And I'm not HULK, either.
    Agreed. I tend to kick out any accumulated snow when I get to my destination. I'm not sure it really makes any difference, but gives back full clearance for moving the tire for the first minute or so of the ride lol.
    I read somewhere that spraying the non-stick cooking spray on the mudguards will help keep the spray/snow from accumulating as badly. I haven't tried that yet, though.
  18. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I added the smaller US version from Prius Chat Shop on mine. It definitely keeps the road spray off of the car downstream from the rear of the tires. Like others, this is the first car that I have owned that did not already have these as standard.
    Of course it cannot help the spray from vehicles around you :cool:
  19. pauln64
    77
    Macon, GA
    I may have to give those a shot. I'm not too worry about the spray but rather stones that the tires may throw down the side of the car.
  20. our1vue
    our1vue Member
    313
    58
    NY
    Question.
    Do the mudguards screw into something metal or just into plastic ? On the Vue that I have, they give you metal clips that you slip on the fender liner to give the guards something to hold on to. I wonder if putting the euro mudguards on screwed into plastic would rip out after a few snowy trips. Thanks for the info
