Adding oil, what the manual says
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by C Clay, Apr 10, 2023.
  1. C Clay
    C Clay Member
    386
    75
    Lexington, KY
    2019 Prius
    L Eco
    Sometimes I run what I call in the “low oil range” when I drive interstate drives a lot, and that is rare (most months I don’t go over 60). It’s a stresser because I typically don’t keep oil at the house or in the car, I just go get an oil change.
    Just for fun, I googled some things and researched the manual. The manual says you aren’t “low” until you get below the point on your dipstick. What do the engineers at Prius Chat say?
    I’m about to head out on a 300 mile journey and I really don’t want to buy oil if I don’t have to- I’d rather wait about 800 miles or so and get an oil change and tires rotated. I’m down in the bottom quarter of the space before low.
    First world problems I know.
    iPhone ?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    So, with about 1" between the high and low marks, you're ~1/4" above the low mark. Still considered to be in the 'normal' range.
    It all depends on your comfort level. I try to check my oil level at least weekly. If the level is at the 'halfway' point between the marks, I typically top it off. Oil is cheap. Engines are not.
    Any time I'm getting ready for a longer than "typical daily" trip, I always verify the condition of the vehicle. This includes topping off all possible fluid levels.
    Is the car in danger if you run it as-is? Probably not.
    Brian1954 and C Clay like this.
  3. Mendel Leisk
    42,151
    If you’re consuming oil, for sure start out with the oil at the top mark, and bring along a quart, funnel and a few paper towels, say in sturdy plastic bag.
    The picture posted is generic? Prius owners manual says it’s 1.6 qt (1.5 liter) between the 2 pips on Prius dipstick.
    #3 Mendel Leisk, Apr 10, 2023
    Foxglove and Grit like this.
  4. Eddie25
    Eddie25 Active Member
    503
    212
    MI
    Just make sure that if your car burns oil you're not running low by the time you get a chance to top off or get an oil change, or whatever.
    C Clay likes this.
  5. C Clay
    C Clay Member
    386
    75
    Lexington, KY
    2019 Prius
    L Eco
    It’s from the manual.
  6. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    As someone who started with a motorcycle the engine of which seized before it was ridden to my home by a “mechanic”, I would opine that the risk reward is not worth both not topping off your oil before your rare long trips and not carrying oil with you. Oil is cheap at Walmart and Costco
    C Clay likes this.
  7. bisco
    52,662
    how is it more cost effective to change the oil every 800 miles?
    Grit likes this.
  8. C Clay
    C Clay Member
    386
    75
    Lexington, KY
    2019 Prius
    L Eco
    Change the oil in 800 miles rather than buy a quart now.
    iPhone ?
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Nothing more fun than driving 80 mph for hours and your really low on oil. Engines really love that. Especially Toyota engines with there low tension crappy rings.All so you don't have a to buy a quart of oil. Brilliant!
    What could go wrong?
    #9 edthefox5, Apr 11, 2023
    C Clay and Grit like this.
  10. bisco
    52,662
    if you're replacing 4 quarts every 800, that means you're burning a quart every 200?
    even at that high rate, you would have to tun the engine out of oil. so you must be burning a quart every 3-400 miles?
    edthefox5 likes this.
  11. Mendel Leisk
    42,151
    @C Clay what's the miles on it?
  12. Eddie25
    503
    212
    MI
    He's saying that he's getting an oil change in 800 miles, not that his car does or does not burn oil. Essentially if he's not low and he's not burning oil, he is wasting money by adding it now only to have it replaced in 800 miles.
    Valmeadian and bisco like this.
  13. bisco
    52,662
    LOL, i was thoroughly confused, thanks!
  14. Doug McC
    Doug McC Senior Member
    1,087
    427
    Midwest
    2022 Prius
    “The “engineer” on PriusChat. LOL!
    That being said, you trust PriusChat over Toyota Engineers? As we used to say in Texas “Houston, we have a problem”
  15. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Yep lifetime fluid is what they also said.
    edthefox5 and Paladain55 like this.
  16. Doug McC
    1,087
    427
    Midwest
    2022 Prius
    Mine uses “Toyota Super Long Life Coolant”. No mention of “lifetime coolant” in any of the Toyota documents that came with mine, however, I do see it mentioned here a lot!
  17. bisco
    52,662
    tranny fluid, not coolant
    edthefox5, Grit and Mendel Leisk like this.
  18. C Clay
    C Clay Member
    386
    75
    Lexington, KY
    2019 Prius
    L Eco
    265,000
  19. Mendel Leisk
    42,151
    You've had it since new? If so, was the EGR system and intake manifold ever cleaned?
  20. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I don’t think it’s a good idea to run low on oil. Too much risk. A quart of oil is cheap and they sell it in resealable containers. The parts shop can give you a disposable paper filter. Check oil when the car is cold, before you drive it in the morning.
    You’re at 265,000…. Your car is a senior citizen and you need to take care of her health if you want to keep her alive. You don’t need fancy expensive oil, just keep it topped up to stay safe. It worth the risk.
    edthefox5 and C Clay like this.
