Adding rear speakers
Discussion in 'Prius c Audio and Electronics' started by Rick Smih, Sep 29, 2012.
  1. Rick Smih
    Rick Smih Junior Member
    I
    I just bought a 2012 c1 and would like to add rear speakers. From reading another thread it looks like there are no wires in the rear door. Is it a big deal to run wires and is there a harness behind the radio for the rear speakers. I'm somewhat handy but by no means an expert. I'm also a little worried about breaking clips removing panels. Any advice would be greatly appreciated.
  2. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,455
    92
    I just took my 2012 C1 to the local car audio shop. They installed a pair of rear speakers and the necessary wiring for $175.
    I was skeptical that they might just splice them in with the front speakers. But the Fader control works which implies they did it the right way.
  3. 2015Prius2
    2015Prius2 Member
    150
    67
    You need to buy a $20 (1987-current) rear speaker plug/harness that will plug to the back of the radio and has about 8 inches of wire to connect your new speaker wires. My suggestion is run them under the rocker panel moldings and up into the molex plug that supplies the wiring thru the b pillar to the rear door.
  4. Rick Smih
    I
    Thanks for the info, looks like rear speakers in the near future.
