Adding secondary battery for 12v outlets
Discussion in 'Gen 3 Prius Accessories and Modifications' started by bensmail, Jan 18, 2010.
  1. bensmail
    bensmail New Member
    16
    Maine
    I'd like to have the outlets work even when the car is off.
    I'm thinking about wiring up a small 12v lead acid battery directly to the 12v outlets so that it would charge up when the car is running but when the car is shut off (and normally the outlets would stop working) they will take power from the secondary battery.
    I can't think of why this would not work.
    Will any other devices stay on at that point? (be powered by the secondary battery)
  2. Oddest_raindrop
    Oddest_raindrop New Member
    75
    wisconsin
    I'm not sure you would have to take a careful look at where the relay is for the outlets. But as an alternative I might suggest putting the 2 outlets or other outlets off that new battery with a battery isolator. It's a device commonly used in RV'ing and is available at a few places. It will allow the new battery to charge but not draw off the existing battery when it's not charging. 2-battery System Battery Isolators - JCWhitney is an example of one. I might also suggest a deep cycle battery for the aux too.
  3. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    I have constant power source for my GPS, Cell Phone Charger, Radar Control remote control unit, Bluetooth headset charger, and Laptop charger.
    When they are not charging devices they consume less then 50mA. This would take over a year to drain the batttery in the car. Here is a pic of the wires I connected to.
  4. Patrick Wong
    18,200
    6,464
    If you are referring to the original equipment 12V auxiliary battery, that has an Ah rating in the mid-30s.
    Using simple arithmetic: 0.05A x 24 hours/day x 14 days = 16.8 Ah. Usually you don't want to drain the battery more than 50% if you are interested in long battery life.
    Or if you don't care about long battery life, you can see that the battery will be completely depleted after one month.
  5. Judgeless
    1,821
    255
    Cleveland, OH
    Using simple logic: Drive car, alternator charges battery. It will never sit more than a week. If it does I will unplug the chargers.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Patrick's comment was simply correcting the error in your earlier post, where you stated it would take over a year to drain the battery. Those small loads add up over time.
    Another small correction: the Prius does not have an alternator.
    Tom
  7. Judgeless
    1,821
    255
    Cleveland, OH
    Looking at the big picture. My chargers that are directly connected to the AUX battery will not drain the battery if I drive the car more than once a week. The regenerative system in the Prius will charge the AUX battery. I am simply pointing out that the battery gets charged and it will not be depleted after one month as Patrick Wong stated.
    I drive my car 30,000 miles a year. This config will work perfect for me and many others.
  8. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    Just a quick correction -- The Prius does not have an alternator, the 12v battery is charged by the dc to dc converter whenever the car is in the ready mode. Also, regeneration helps charge the traction battery, not the 12v battery.
  9. Judgeless
    1,821
    255
    Cleveland, OH
    Do you really belive the 12V AUX battery never gets charged by the car?
    The Prius has a permanent magnet AC electric motor. This motor functions as a motor and a generator (AKA alternator). The AC output goes to a bridge rectifier and converts it to DC. The DC output uses a DC to DC converter to output 12-15V to drive components in the car and charge the AUX battery.
  10. ken1784
    ken1784 SuperMID designer
    2,940
    1,359
    67
    Yokohama, JAPAN
    The MG1 and MG2 are never called alternator.
    In your theory, your Prius only charges the aux battery on regeneratiing, but it is not correct. Also, there is no bridge rectifier.
    The aux battery is charged anytime in ready mode using HV battery power via DC-DC converter.
    Ken@Japan
  11. Judgeless
    1,821
    255
    Cleveland, OH
    An alternator is an electromechanical device that converts mechanical energy to electrical energy in the form of alternating current. That is exactly what MG1 and MG2 does. They are one in the same.
    Those Diodes in your pictures are a bridge rectifier.
  12. qbee42
    18,058
    3,073
    Northern Michigan
    When generating, an MG does indeed operate as an alternator, but no one would ever refer to it as such. It's simply a matter of terminology, much as one would never call a concert violinist a fiddle player.
    Ken is an excellent engineer. I'm sure he recognizes the bridge rectifier in the schematic.
    As long as we are splitting hairs over terminology, the MGs on the Prius are not permanent magnet MGs, but are hybrid synchronous MGs. They do have a permanent magnetic field, but they also use an induced field at higher power levels. This means they run as efficient permanent magnet motors at low power levels, but transition to more powerful but less efficient induction motors at high power.
    No one is trying to beat you up over a simple term like alternator. It's simply a matter of clarification. People come onto this forum and read the term alternator and assume the Prius has a conventional automotive alternator hanging on a belt somewhere. It doesn't, so we want to avoid the confusion.
    Tom
  13. Patrick Wong
    18,200
    6,464
    MG1 and MG2 are not alternators, given your definition above. MG1 and MG2 will also convert electrical energy to mechanical energy. Alternators typically do not perform that conversion.
    Two examples of electrical to mechanical energy conversion:
    - MG2 is directly coupled to the transaxle output shaft, and powers the car when the gasoline engine is not operating.
    - MG1 starts the gasoline engine.
    Regarding the diodes in Ken's schematic, it appears that the purpose of those diodes is to protect the IGBTs by limiting the reverse voltage that would otherwise appear across the emitter - collector junction?
  14. bensmail
    bensmail New Member
    16
    Maine
    I cannot tell from the picture what was done here. Were you jumping the accessory power to permanent power? If so, can't this be done at the fuse panel?
    I'm interested in adding a second battery so I do not need to worry about draining the car battery. Let's say I want to run a portable DVD player for an hour. I know they don't use much power but want to eliminate the chance of draining the battery not increase the chances.
  15. ken1784
    2,940
    1,359
    67
    Yokohama, JAPAN
    Again, in your theory, your Prius only charges the aux battery on regeneratiing.
    Place your voltmeter on the 12V line.
    In READY mode, you'll see consistent approx 14V even in neutral at standstill.
    In ACC or IG-ON mode, you'll see less than 12.5V, and it shows the the DC-DC converter is disconnected from HV battery.
    That's the evidence that the aux 12V battery is charged by the HV battery power via DC-DC converter.
    Ken@Japan
  16. Judgeless
    1,821
    255
    Cleveland, OH
    That is splitting hairs. The motor type is Permanent magnet AC synchronous motor. I am sure it is enhanced, but its still a Permanent magnet AC motor.
    Why would he post this? With a picture of a bridge rectifier?
  17. Judgeless
    1,821
    255
    Cleveland, OH
    That is what I said a few posts back
  18. Judgeless
    1,821
    255
    Cleveland, OH
    Getting back to my original post. It is ok to connect devices to constant power as long as they do not consume to much energy. The vehicle will always keep the Aux battery charged.
    I was trying to make a simple point and you guys went down an odd path. I am an Electrical Eng. and I work with motor control applications.
  19. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    What they are trying to point out, if I understand it, is that the MGs (through the inverter) charge the HV battery, and the HV battery supplies the power to the DC to DC converter (and thus the 12 volt) in Ready mode whether the MGs are turning or not. Also, that the MGs never send power to the 12 volt or to the converter, except through the inverter/HV steps.
    But I am not even an engineer, so not claiming to know anything.
  20. ksstathead
    1,244
    243
    Kansas
    I read that there is concern over battery life among those with short trips, due to the conservative rate of 12V charging, so at the margin, these small extra loads could make matters somewhat worse. Does adding a 2nd 12V battery to the recharge scenario reduce the charging of the primary 12V? Are BMS isssues a concern with 2 12V's?
